Fraud wrote:Could be missing by the sound of it. Have you had the car long, and has it done this for awhile?
While its idling, pop the bonnet and have a look at the motor. Does it move around when it chugs?
gothegravel wrote:How far advanced is your timing. It is possible to run the 4k well advanced depending on your mods. come back to me.
Mmm, Boost wrote:Intake/exhaust manifold leak
Loudtoy wrote:inlet manifold may be leaking after the carb as well, had same problem on my one sorted with a new manifold, you may be able to hear it leaking if it's bad enough. Otherise it will be a combination of timing and mixture, but nothing to worry about unless it is running lean which can be checked by seeing what colout your sparkplugs are
scope wrote:Mmm, Boost wrote:Intake/exhaust manifold leak
will check for this, thanks. does this account for the backfiring also?
