idle not staying still and backfiring (4k)
Postby scope » Thu Jan 05, 2006 1:32 pm
hello
my idle moves from 700rpm to 900rpm, it won't stay still. what is the reason for this? it kind of sounds like it's doing little backfires also if i stand by the exhaust
and that brings me to the second question. when i'm slowing down using the gears, the car will backfire really loud and alot of times. also happens when i'm going down hills. i've heard before that this is just because of a 4k and having an exhaust (2") but just wanted to make sure
thanks
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Fraud » Thu Jan 05, 2006 5:37 pm
Could be missing by the sound of it. Have you had the car long, and has it done this for awhile?
While its idling, pop the bonnet and have a look at the motor. Does it move around when it chugs?
Fraud
Postby mad_te71 » Thu Jan 05, 2006 11:29 pm
check your points in the dizzy and check the spark plug gaps or it could be sumtin to do with the carb.
[User is Suspended. Offensive Sig Removed]
mad_te71
Postby Ae92typeX » Fri Jan 06, 2006 8:44 am
as above check those things. You could get those problems from running very lean in the carb.
check that, plugs, timing and exhaust for leaks.
Ae92typeX
Postby Go_the_mini » Fri Jan 06, 2006 5:52 pm
i also get this in mi 4k, and the engine shakes so much somtimes i feel like im guna fall out the window, mine is a mixture of timming being out causing it to misfire and the car running to rich which i think has somthing to do the fact that the carb has an auto chock and the car is manual.
Go_the_mini
Postby scope » Fri Jan 06, 2006 7:47 pm
Fraud wrote:Could be missing by the sound of it. Have you had the car long, and has it done this for awhile?
yeah it moves. the whole car shakes
what about the backfiring?
scope
Postby vhpacer » Sat Jan 07, 2006 3:59 pm
Is the engine stock standard just with the exhaust?
If it is try turning the mixture screw anti-clockwise half a turn.
vhpacer
Postby fatgtr » Sat Jan 07, 2006 9:56 pm
check your ignition timing, also check for fouled plugs
James
gotta love the punk music
fatgtr
Postby Loudtoy » Sun Jan 08, 2006 10:25 pm
inlet manifold may be leaking after the carb as well, had same problem on my one sorted with a new manifold, you may be able to hear it leaking if it's bad enough. Otherise it will be a combination of timing and mixture, but nothing to worry about unless it is running lean which can be checked by seeing what colout your sparkplugs are
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
miss
Postby ATOYOTA » Wed Jan 11, 2006 8:02 pm
also check replace the condencor
its a smal component that looks like say half a battry
its bolted to the distributer
ATOYOTA
Postby gothegravel » Thu Jan 12, 2006 9:04 pm
How far advanced is your timing. It is possible to run the 4k well advanced depending on your mods. come back to me.
gothegravel
Postby Dell'Orto » Thu Jan 12, 2006 9:17 pm
Intake/exhaust manifold leak
Postby vvega » Thu Jan 12, 2006 9:57 pm
Mmm, Boost wrote:Intake/exhaust manifold leak
for teh win
vvega
Postby scope » Thu Jan 12, 2006 11:39 pm
gothegravel wrote:How far advanced is your timing. It is possible to run the 4k well advanced depending on your mods. come back to me.
it's not advanced at all that i know of
will check for this, thanks. does this account for the backfiring also?
Loudtoy wrote:inlet manifold may be leaking after the carb as well, had same problem on my one sorted with a new manifold, you may be able to hear it leaking if it's bad enough. Otherise it will be a combination of timing and mixture, but nothing to worry about unless it is running lean which can be checked by seeing what colout your sparkplugs are
what colour would they be?
scope
Postby mad_te71 » Fri Jan 13, 2006 12:20 am
if their black its running rich if its greyish white its leaning out :roll:
mad_te71
Postby Dell'Orto » Fri Jan 13, 2006 11:50 am
Yup, most definately.
Postby scope » Sun Jan 15, 2006 11:17 pm
what's an easy way to find the leak? can i put some liquid shit on it like dish washing liquid or something :lol: and see where it bubbles? heh
scope
Postby gothegravel » Sun Jan 15, 2006 11:20 pm
your on to it....what inlet manifold re you running?
gothegravel
Postby scope » Mon Jan 16, 2006 12:02 am
just a standard one
scope
Postby Dell'Orto » Mon Jan 16, 2006 1:35 pm
You havent fixed this yet? 8O Gasket is like $10 from Repco, and it'll take all of half an hour to do :P
