Blacktop 4AGE Q's
Blacktop 4AGE Q's
Postby Lanci » Mon Jan 09, 2006 5:59 pm
Hi guys,
Did a search and found nothing definitive so here goes,
What oil is recommended for the engine? From what I saw anything over 10 grade and not fully synthetic, is this correct? (I was thinking of using Castrol magnatec).
Do these engines have a habit of chewing through oil even when in perfect condition? (I currently use 1 litre of oil per 2 months, that is grade 5-50)
Help much appreciated,
Lance
Back to the Nissan 200sx family, so no Toyota Chaser in my garage.
Lanci
Postby Ae92typeX » Mon Jan 09, 2006 8:39 pm
depending on the mileage the car has on it, 1l per 2months aint bad- pleantly of people on this site who's 20v's use about that.
In the castrol range the magnatec will be fine. Ifg you switch to say 10w-40 rather than the 5w50 you are now, it might use a little less.
Ae92typeX
Postby TrouserFxGt » Mon Jan 09, 2006 9:11 pm
From the engine manual.
10w-30, 15w-40, 20w-50 sg or sh multigrade engine oil.
If its good enough for toyota its good enough for you.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby BZG Wagon » Mon Jan 09, 2006 10:25 pm
Yes; the 20v's seem to consume oil. I spoke to a mechanic at Toyota who reckoned its due to the valve seals hardening and oil escaping. He said most 4 cycl Toyota engines have a thirst for oil.
Im not sure how much I use in litres, but for every 1500kms the oil will drop from the max level on the dipstick to just over the lowest level on the dipstick.
I use Castrol Magnatec and had no problems.
BZG Wagon
Postby Otomo » Mon Jan 09, 2006 10:26 pm
If you don't rev your engine too high most of the time Magnatec would work fine. But if you want better protection, fully synthetic would definitely be the choice - Magnatec is only semi-synthetic.
I don't know if it's marketed in NZ, but Castrol has the Castrol Formula RS fully synthetic with a 10W-40 grade that works quite well.
I also used Castrol SLX Fully synthetic 0W-30 when I used to drag and found no problem whatsoever...but this would be dependent on your engine's condition.
Waaaaaaaahhhhhh!!!! PANG! PANG! PANG! BOOOOOM!!!
Otomo
Postby TruenoBZG » Tue Jan 10, 2006 8:52 pm
I use magnatec - runs great.
Uses a bit of it too (apprx. 4 litres every few months) especially on long trips or on occasions when my accelerator foot feels suprisingly heavy...
'96 Trueno BZ-G
TruenoBZG
Postby quinny » Tue Jan 10, 2006 11:50 pm
my blacktop lives at redline regulary and does 3-4000k's a month and
drinks around half a litre of cheap ass regular repco oil a month. Not often really i have to top up on 5000k oil changes.
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby Lanius » Wed Jan 11, 2006 12:41 am
Otomo wrote:If you don't rev your engine too high most of the time Magnatec would work fine. But if you want better protection, fully synthetic would definitely be the choice - Magnatec is only semi-synthetic.
I've heard or read somewhere that fully synthetic isn't the oil of choice for a 20valve ... to do with the vvt I think?
I use magnatec 10W40 in mine and it seems to go just fine. Both black and silvertops are known for being thirsty oil-wise.
Lanius
