AE101 Corrola FX-GT Manual Electrical question
Postby PreacheR » Mon Jan 09, 2006 6:58 pm
Sorry if this has already been covered.
My Rolla is doing something strange. When shifting my stereo cuts out but only when shifting in into 1st 3rd or 5th and sometimes when passing through the nuetral position. The stereo setup is not fancy. Its a Clarion DXz846mc (parrallel Imports Rock) There is no external amp. There are active cross overs for the front speakers.
Any rock star ideas?
Current Ride
92 Ae101 Corolla FX-GT
Previous Ride's
1993 BMW E36 320i Coupe
1987 BMW E30 320i Coupe
1979 BMW E21 520 TANK
~PreacheR~
"...Dinosaur fossils? God put those there to test our faith."
"I think God put you here to test my faith, Dude"
-Bill Hicks
PreacheR
Postby EssDub » Mon Jan 09, 2006 7:06 pm
Got any bare wire that may be touching against the shifter at any stage?
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby PreacheR » Mon Jan 09, 2006 7:09 pm
Pulled of the shifter cover and couldn't see anything. Is there much wiring beneath the shifter?
Current Ride
Previous Ride's
~PreacheR~
-Bill Hicks
PreacheR
Postby neo » Mon Jan 09, 2006 7:13 pm
possibly someone has run a cable under the 2 shifter cables, when the right one is pulled (1,3,5th) it disconnects the stereo... Probably the earth wire.
neo
Postby PreacheR » Mon Jan 09, 2006 7:15 pm
Being a bit of twit, what would I go looking for and where?
Be kind Gods of Toyota knowledge....
Current Ride
Previous Ride's
~PreacheR~
-Bill Hicks
PreacheR
Postby Ae92typeX » Mon Jan 09, 2006 8:36 pm
if you are able, pull the headunit out and check that all the wires are connected properly and insulated/wripped in wire properly. As above, sounds like a wire is shorting or disconnecting somehow. check where the earth wire is and perhaps reposition it.
Ae92typeX
