Not boosting right, engine light on. HELP
Postby GT4PWA » Sun Jan 15, 2006 11:49 pm
need some help with whats happening wit my car. About 2 weeks ago sometimes when the car hits 3k revs you se on my IBC is hitting 10psi the wastegate kicks in but the cars not boosting its accelerating normanally or sometimes starts losing speed.
Then today when trying to fix my boosting problems it ran unlimited boost once cut out at 18psi now the engine light stays on perminatly and to make things wrse the issue above now happens everytime i accelerate past 3k revs, until then it seems to accelerate fine.
Finially to make thigns even worse before all this started happening from about 2 weeks ago sometimes when accelerating the engine sort of cuts out while accelerating.
have you guys got any ideas on what coudl be wrong things i can do to fix and how much?
GT4PWA
Postby kilowatts » Mon Jan 16, 2006 12:00 am
Sounds like a knock sensor, $50 bucks for the part and fit it yourself.
current rides: 1994 toyota hiace, 1998 toyota hiace, 1998 toyota supra/na,2000 toyota caldina gtt,(1993 toyota fxgt has just been sold)
kilowatts
Postby Mr Revhead » Mon Jan 16, 2006 12:05 am
could be knock sensor. got heaps of black smoke as well? real gutless?
you need to check ya codes to confirm
Postby Malcolm » Mon Jan 16, 2006 2:24 am
sounds like you should check your error codes before guessing at what the problem is.
Postby GT4PWA » Mon Jan 16, 2006 2:36 pm
How do i check for the error codes? Its booked back into the mechanics on thursday thanks heaps for your help will keep you guys posted
GT4PWA
Postby Silent Knight » Mon Jan 16, 2006 2:41 pm
In the Engine bay you find your little diag box and bridge terminals E1 and TE1.
Switch your car 'on' (meaning don't start it.) and look at the Check Engine Light.
Count the flashes and then do a search on the forums for the Toyota Error Codes and it should give you all you need.
Silent Knight
Postby Silent Knight » Mon Jan 16, 2006 2:42 pm
Actually here I've done the Search for you:
http://forums.toyspeed.org.nz/viewtopic.php?t=35814&highlight=error+codes
Now when is a MOD going to sticky that thread or move it into FAQ?
This same question pops up so damn much!!!!
Silent Knight
Postby GT4PWA » Tue Jan 17, 2006 2:01 pm
thanks silent knight i'll see waht i can put together and will let you guys know. thanks alot for the help
GT4PWA
Postby DFECTED » Tue Jan 17, 2006 7:19 pm
sounds the same as what mine is doing.
I get error code 22 52 54
There are lots of sites that have the list of error codes but I cant find what 54 is?
It also cuts at 3k and if you keep it floored the revs drop to idle then it stalls, if you lift off and feather the gas a little it has a bad misfire.
Ive changed the plugs, leads, distributer cap and the coil..
DFECTED
Postby GT4 20 » Tue Jan 17, 2006 7:30 pm
DFECTED wrote:There are lots of sites that have the list of error codes but I cant find what 54 is?
Pretty sure that's the WAI code?
Gray
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Malcolm » Tue Jan 17, 2006 8:57 pm
yeah 54 is w/a system error, can be anything from a bad pump to low fluid level or broken float sensor.
Postby DFECTED » Tue Jan 17, 2006 9:10 pm
ok, that wont cause it to run like it does though will it?
wheres the knock sensor on a st165?
DFECTED
Postby sergei » Tue Jan 17, 2006 9:14 pm
22 52 54 are exactly same codes I was getting when I was hitting boost cut on my ST165! I fixed it by winding boost down (~10psi, anything above and I get random boostcuts on high gear low rpm)...
Postby sergei » Tue Jan 17, 2006 9:18 pm
BTW I have Intercooler Controller bypassed, I have second water pump, I run ST205 I/C, straight intake pipe with TRD pod filter in a cold place, gutted cat, 2.5inch mandrel exhaust with cheap chambered muffler, I run leagy I/C radiator, I have no TVIS, no TVSV, No FPR Solenoid, no Fuel pump resistor...
Postby sergei » Tue Jan 17, 2006 9:19 pm
knock sensor is above transfer case inbetween 4th and 3rd cylinder on back side of the block.
