Noisey on coast
Noisey on coast
Postby BLKTOP » Mon Jan 23, 2006 6:51 pm
If there is a slight noise coming when your coasting from the gearknob or there abouts area what would this mean? Only comes on coast and goes off when you press the clutch. Noise is very slight but stil audible. Anything i can do to stop the noise? Sounds like a noisey small fan (if that makes sense?!)
Thanks!
BLKTOP
Postby solberg Fan » Mon Jan 23, 2006 9:11 pm
Im not sure about gearbox noises, but could it be coming from the diff on overrun? check the gearbox level. Im assuming its front wheel drive, if not check the diff also.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby BLKTOP » Mon Jan 23, 2006 10:02 pm
its more of a whining noise. comes when when the foot is taken away from the accelerator. it only seems to be in 2nd and 3rd gears so it must be a gearbox issue? What do you mean by gearbox level? Noise dissapears as soon as i press the accelerator again. Thanks!
BLKTOP
Postby Ae92typeX » Mon Jan 23, 2006 10:31 pm
level means fluid level, is that ok?
could possibly be an input bearing (or other bearing). Input ones go every now and then, although they wine in all gears generally...so maybe not.
could try some heaver fluid, but thats not necessarly stopping a potential issue.
Ae92typeX
Postby Ae92typeX » Mon Jan 23, 2006 10:34 pm
sorry, didnt read the question fully...
so its just from the stick?
and we are talking about fwd yes?
Ae92typeX
Postby Jazza » Mon Jan 23, 2006 10:36 pm
If BLKTOP is driving the curren in the avatar, yes, fwd... but ill let them answer that themselves.
Dont know of anyone whos dont a rwd conversion on a curren. I wanna be the 1st :P
1996 Curren - On Tardme
Jazza
Postby Ae92typeX » Mon Jan 23, 2006 10:38 pm
Jazza wrote:If BLKTOP is driving the curren in the avatar, yes, fwd... but ill let them answer that themselves.
hence the question. people dont always drive what the avatar shows...if I drove a cartoon mini i wouldnt get far... :lol:
Ae92typeX
Postby BLKTOP » Tue Jan 24, 2006 9:37 am
sorry for not making my question clear. Yes its a 1997 curren ss2. manual. 3sge. fwd. To me it seems to be coming from somewhere around (or slightly in front of ) the shift knob area. Yeah the whine is audible in 4th as well i suppose. not too sure about 5th and 1st. Car is pretty quiet except for that so its a bit annoying (Its always something isnt it!). Thanks!
BLKTOP
Postby Jazza » Tue Jan 24, 2006 9:47 am
How many owners before you? Could be the gearbox getting ready to head out... My civic started making noises like that and (I dont mean to alarm you) bam, a month later, gearbox died.
Although mine were more intermitent noises, they started then stopped and started again... ill read up on the subject and try help out.
Jazza
