geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
AE85.6 wrote:why are they wider ? i sense some hilux input ?
fx gt wrote:Low_Aa63 wrote:AE85.6 wrote:why are they wider ? i sense some hilux input ?
offset noob
$&#$% your a toss 0n ts,you lik saying noob alot 2
AE85coupe wrote:I think if you get flares it will be o.k
as for Low_Aa63
i'm sure it could well be the offset, but it could also be a hilux setup, due to the fact hilux diffs tend to be wider and can stick the wheels out further
it doesn't really matter what it is
but calling someone a noob who is actually correct in his question
makes you the noob Low_Aa63
Low_Aa63 wrote:And if that diff wasnt shortened the wheels would protrude alot further than that!
AE85coupe wrote:i'm guessing you will be getting a low volume cert for your car rick?
so it should be sweet as
