Santa's Track Car - AE92
Postby Santa'sBoostinSleigh » Wed Jan 25, 2006 2:03 pm
well as some of you may know, i've acquired myself an AE92 Corolla, and it looks like this will become my track car.
eventually it will be caged, and will be kept road legal
i have a blacktop motor and LSD gearbox to go in, along with a pair of bucket seats, aftermarket s/wheel and a couple of sets of 15" mags.
but what other fun things should i add/do?
suspension setup?
exhaust setup/size?
other mods/tips/hints/ideas?
car will be used in track events, car club events and such like :)
(please dont post rubbish or things like 'cool' - it will be deleted, there is a button that says 'watch this topic', you dont need to post something to follow whats going on)
cheers in advance
Andrew
Last edited by Santa'sBoostinSleigh on Wed Jan 25, 2006 2:45 pm, edited 2 times in total.
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby strx7 » Wed Jan 25, 2006 2:06 pm
spend the coin on
A) suspension
b) Brakes
c) good quality seat ie:racetech FIA approved item and an FIA approved harness with 5 year lifespan
Postby Santa'sBoostinSleigh » Wed Jan 25, 2006 2:12 pm
ah, forgot to mention, im using the superstrut brakes off the levin i stole the motor/box from
already have seats, and that is the plan for belts
if anyone has mean hookups on belts/race tyres/suspension etc let me know ;)
Santa's Mega Sale
Postby Leon » Wed Jan 25, 2006 2:34 pm
My set up has worked well for a general use club car, without spending much money.
King Springs (could easily be substituted with TRD), not super low.
KYB shocks, good for the cost
Whiteline rear sway bar ( @#)(@#)@#)ing fun)
Mintex 1166 pads in the front
I think this is much the same as Disturb has in his car too, maybe different brake pads?
Postby Santa'sBoostinSleigh » Wed Jan 25, 2006 2:47 pm
Leon, have you got some approx costs on some of the goodies? and/or good places to aquire them from?
Santa's Mega Sale
Postby Distrb » Wed Jan 25, 2006 2:59 pm
Yep, im running the same setup as leon, but i'll elaborate a lil bit. Its quite basic, and is the same as i ran at manfield on the weekend.
Kyb Shocks - Just standard replacement spec, nothing flash
Low King springs - not superlows
Whiteline 20mm adjustable rear swaybar - provides maximum grin factor
Mintex M1166 Compound pads
Custom Braided Brake Lines
Shocks and springs i got from Stocks, Swaybar from Mr Revhead, Pads from 0800 Racebrakes, and the Braided lines from ABC
Prices on all of the above i cant say.
Personally i rekon you should get the stuff you already have in the car and up and running :D
Distrb
Regular Poster
Postby 2LTR Rona » Wed Jan 25, 2006 3:04 pm
What about the fluids side of things D ???
Standard middle of the road or have you stepped it up a notch or two there as well?
2002 Altezza, 1974 KE25
2LTR Rona
Postby Distrb » Wed Jan 25, 2006 3:07 pm
2LTR Rona wrote:What about the fluids side of things D ???
Using some motul fluid.... standard spec, just changed regularly 8)
Distrb
Regular Poster
Postby Leon » Wed Jan 25, 2006 3:14 pm
Better brake fluid ... can't recall what. Picked it up from BNT at a reasonable price. Wasn't silly price race fluid or anything flash, just good off the shelf stuff. Also, as Andrew said, keep it fresh.
Springs ~ $400
Shocks ~ $250?
Swaybar ~ $300
Pads ~ $120
that's all total ballpark figures from vague recollections.
Postby Low_Aa63 » Wed Jan 25, 2006 3:41 pm
have you considered forced induction??
the ultimate goal could be something like a black top 20v 7A-gte
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby Santa'sBoostinSleigh » Wed Jan 25, 2006 3:43 pm
nope- got my motor and not turbo'ing it, end of story on that one
Santa's Mega Sale
Postby Leon » Wed Jan 25, 2006 3:52 pm
Plus, if you turbo a 1600cc the rating for motorsport events is suddenly multiplied by 1.7. So your 1600cc car is now 2720cc as far as what class you are placed in.
Generally speaking, this is a baaaaaad place to be as far as your in class results go.
Postby IH8TEC » Wed Jan 25, 2006 4:13 pm
pm bazda about the coilovers he has, he now has a set in his car also, have camber plates etc, must be good if he's got them in his car,
viewtopic.php?t=41005
viewtopic.php?t=42197
Postby strx7 » Wed Jan 25, 2006 4:14 pm
you'll generally find at motorsport events that 1601-2000 class has less competitors and is easier to win
Postby B1NZ » Wed Jan 25, 2006 5:33 pm
strx7 wrote:you'll generally find at motorsport events that 1601-2000 class has less competitors and is easier to win
apart from the fact that there are oodles of CRX's, Civics and Integras which power to weight whip the shit out of ae92's unfortunatley :cry:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby KinLoud » Wed Jan 25, 2006 5:36 pm
Good plan,
Get the car going with what you have. Bolt everything in that will bolt in from your AE111.
Then once it is running you can decide if you need adjustable height coilovers etc. Most guys I race against just run standard suspension setup with higher rate springs and new shocks, nothing fancy.
I presume you will be keeping road legal? It's a good idea if you have the option of driving your car to an event... saves having to own a trailer. You can borrow a trailer if the event is a long way from home.
Talk to a certifier before you start modding bits to fit. This will make it easier to get it certed if the guy is in the loop from the beginning.
Superstrut brakes:
I'm getting my Marino certified tomorrow. Amongst other things, I have put superstrut brake disk and caliper and modified non superstrut hub onto the car. Talk to me about how this was done and what the certifier said when I showed him the hubs and brakes.
Ken
Hamilton
021 408 863
Postby strx7 » Wed Jan 25, 2006 6:20 pm
apart from the fact that there are oodles of CRX's, Civics and Integras which power to weight whip the sh*t out of ae92's unfortunatley :cry:
Apart from the fact that unless that have B18C's in them which most dont, they aren't in the 1601-2000 class. Most run B16 and are in class B 1301-1600
Postby Caveman » Wed Jan 25, 2006 8:10 pm
IH8TEC wrote:pm bazda about the coilovers he has, he now has a set in his car also, have camber plates etc, must be good if he's got them in his car,
Yep you should consider these, ive been tempted as but never seem to have enough money :cry:
Sounds like its going to be awsome. Black top in an ae92 should be very competitive.
What are you doing with the small port?
If it were me i'd just take it out as is for now, just on a few gym khanas and get used to the cars ability without going straight to big power, coil-overs, etc.
Caveman
Postby Santa'sBoostinSleigh » Wed Jan 25, 2006 8:48 pm
hehe my caldinas got way more power than this car ever will :P
i will end up selling the smallport retdtop
Santa's Mega Sale
Postby THA SHZ » Wed Jan 25, 2006 9:25 pm
Santa'sBoostinSleigh wrote:if anyone has mean hookups on belts/race tyres/suspension etc let me know ;)
i may be able to he;p u on tht front , pm me for details 8)
THA SHZ
