top mount studs on coilovers slightly out, wot can i do???
Postby phatman3801 » Wed Jan 25, 2006 9:38 pm
just tryed putting the rear coilovers in my ae111 levin, after spending like an hour trying to put the left rear in i have discovered that whn u get one of the studs through the hole the other to are a few mm's out!! can i just drill the holes out slightly bigger to make them go in or not a good idea??
current project/ride: BZG levin
phatman3801
Postby Jazza » Wed Jan 25, 2006 9:44 pm
From what ive heard thats what ya gotta do. But wait for a 100% answer before you take my advice :wink:
1996 Curren - On Tardme
Jazza
Postby THA SHZ » Wed Jan 25, 2006 9:48 pm
try turning the stut hat first , and if it doesnt fit any way then slot it but put a washer over where u slot it so u dont get pinged on ur warrent 8)
wat type of stut are u tryin to put in ?
THA SHZ
Postby phatman3801 » Wed Jan 25, 2006 9:51 pm
they are a nex coilovers, the right rear went in ok its just the left hand side, and ive tryed every way to get the left side in but the studs are defintly ouut a bit, so drilling the holes out a bit is sweet?
phatman3801
Postby Caveman » Wed Jan 25, 2006 10:16 pm
If you can you should try RMA it, if you bought it locally i'd definatly do this. sounds like there measurements are slighly off
Caveman
Postby phatman3801 » Wed Jan 25, 2006 10:19 pm
RMA? wots that mean?
phatman3801
Postby Mr.Phreak » Wed Jan 25, 2006 10:58 pm
Return material authorization
Mr.Phreak
Postby phatman3801 » Thu Jan 26, 2006 8:04 am
probaly can but will have to wait many weeks for replacement as the guys out of stock, is drilling out the holes ok, or should i be advised not to do it?
phatman3801
Postby TRD Man » Thu Jan 26, 2006 9:12 am
How many mm are you talking phatman?
If it's only one or two get the rat tail file out. The flange on the nut will cover your work and if you do it evenly the strut top will still be centred correctly.
TRD Man
Postby phatman3801 » Thu Jan 26, 2006 9:39 pm
all fixed now only had to take a few mms off!
phatman3801
