how to replace 20v head gasket?
Postby deaf_rattle » Wed Jan 25, 2006 10:01 pm
has anyone done the headgasket in their silvertop 20v?
can it be done with the motor in place?
and i have been told that the front cover is in two parts, so that makes it easy enough to take the top part out to get planed with the head.
anyone got any tips, and how long will it take.
i am tempted just to take it to the mechanics so they can do it while im at work
Postby TRD Man » Thu Jan 26, 2006 9:18 am
deaf_rattle, planing the cam belt/pulley cover?
No offence intended but I think you should take up your own suggestion & leave it to the mechanics.
TRD Man
Postby Vertigo » Thu Jan 26, 2006 11:59 am
having never done it before and only just getting started with this shit, ill say its not too hard. but dont take my word for it.
TVIS just kicked in, yo!
Vertigo
Postby Punter » Thu Jan 26, 2006 12:02 pm
Vertigo wrote:having never done it before and only just getting started with this sh*t, ill say its not too hard. but dont take my word for it.
Yea, I haven't done one on a 4age, but i sure its all much the same. Just following instructions. (that is if you have a manual) If you can do an engine swap you should be able to do a head gasket.
Punter
Postby Silent Knight » Thu Jan 26, 2006 12:10 pm
oH come on Matt!!!
You own a 7M...I would have thought you would be able to change a headgasket blindfolded with one hand tied behind your back by now... :P
Silent Knight
Postby AceSniper » Thu Jan 26, 2006 2:11 pm
id find it had to see ur stock headgaskit has failed as they are carbonfiber
the cam covers can be a pain to unscrew were they are located also
AceSniper
Postby sergei » Thu Jan 26, 2006 2:17 pm
it is best to dissasemble as much as possible (reasonbly) as it will make easyer to put back everything together, and save a lot of time getting to tricky places while it the bits are still hanging off. It pays to change cambelt/tensioner/cam seals/valve stem seals while you are at it...
Postby JT » Thu Jan 26, 2006 4:48 pm
Here's the 'Engine Mechanical' section of the blacktop manual. Few differences with the silvertop but it gives you a good idea on the process.
http://www.onthenet.com.au/~paulp/Blacktop/bt4-em.pdf
JT
Postby Low_Aa63 » Thu Jan 26, 2006 5:32 pm
AceSniper wrote:id find it had to see ur stock headgaskit has failed as they are carbonfiber
bahahaha so true..
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby deaf_rattle » Fri Jan 27, 2006 7:44 pm
TRD Man wrote:deaf_rattle, planing the cam belt/pulley cover?
sorry butt munch, i have done the head gasket on the 7mgte, and there is the front engine cover that needs to be planned as well. i just assumed the 4age would be the same.
should change your name to turd_man unless you are going to be helpful
Postby Malcolm » Fri Jan 27, 2006 8:22 pm
What front cover is that? the oil pump housing?
Postby deaf_rattle » Fri Jan 27, 2006 8:45 pm
The block decks should be resurfaced to the best finish available. Invariably the head gasket will have gouged the surface. Make sure that the aluminum timing cover is on the block when the deck is surfaced, or else the head gasket will not seal properly. We send the blocks and head to a special grinding outfit- that machines aircraft components, and they are able to surface to a mirror finish. Upgrade all the engine assembly bolts. Replace all the hoses. Keep a spare head gasket.
