3S-GE factory specs & megasquirt
Postby StuartM » Wed Jan 25, 2006 10:10 pm
Hello world
im going to replace my 3S-G ECU (1986 ST162 GT-R celica) with a megasquirt v3 and had a couple of questions I was hoping to get answers to.
what CC/minute are the OE injectors?
what is the fuel injector opening/closing time?
is there a MAP sensor anywhere in the car? (supras have one in the cabin!)
is there anyone else out there with a megasquirt-controlled 3s-ge who could send me a msq file to start my tuning with? what Req_fuel and idle PWM did you use? was the stock EGO sensor any good?
StuartM
Postby RomanV » Wed Jan 25, 2006 10:17 pm
First of all, good on ya for giving megasquirt a go.
Very cool. 8)
Karl skewes had a 3sge running on megasquirt, however he was running quads, so his fuel requirements would be rather different.
There is only 1 map sensor, and it tees into the intake manifold.
EDIT: argh, I thought I had the injector sizes written down somewhere, but I dont.
Postby StuartM » Wed Jan 25, 2006 10:25 pm
thanks! I have downloaded his msq files from the garagedori.com website :-)
my stock ECU is an AFM type (should have said it was a 3S-GELU) will it still have a MAP sensor??
StuartM
Postby RomanV » Wed Jan 25, 2006 10:32 pm
Doh! Sorry, youre right, I mistakenly thought it was a gen 2 3sge.
Sorry I dont know much of anything about gen 1 engines, but good luck with your project. 8)
Postby Malcolm » Wed Jan 25, 2006 10:57 pm
if the injectors are green they should be 295cc/min, 13.8ohm
it doesn't have a map sensor, so get one from another NA map sensed toyota :)
Postby Boldy » Thu Jan 26, 2006 7:31 am
FYI megasquirt has a built in MAP sensor. Just need to run a tube from the inlet manifold to the MS.
Boldy
Postby Malcolm » Thu Jan 26, 2006 10:06 am
good to know :)
Postby dodgy » Thu Jan 26, 2006 11:20 am
im halfway thru setting up msns-e on my 3sge. running quad throttles and cop coils.
dodgy
Postby RomanV » Thu Jan 26, 2006 11:27 am
So you're ditching the carbs? or are you using MS for the ignition timing etc?
Postby dodgy » Thu Jan 26, 2006 3:04 pm
got carbs on one engine in AE70, and quad throttles plus msns-e in mr2.
also looking at running msns-e on gen4 with factory intake in AE86 for targa next year. We love our 3sge engines down here!
dodgy
Re: 3S-GE factory specs & megasquirt
Postby spencer » Fri Jan 27, 2006 12:54 pm
StuartM wrote:is there anyone else out there with a megasquirt-controlled 3s-ge who could send me a msq file to start my tuning with?
no point using Karls if you havnt got quads, You'll have a whole lot better megasquirt experience if you start from scratch just go read the mega manual about 10 times
spencer
Postby JamesM » Fri Jan 27, 2006 11:43 pm
yah megasquirt :)
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Users browsing this forum: No registered users and 22 guests
