Distributor & Rotor Help
Postby BZG Wagon » Mon Jan 30, 2006 11:16 am
If I replace my Distributor Cap and Rotor, will I need to redo the Timining on my car?
My initial thought is that I shouldnt have to, as the cap sits after the adjustment, but I just want to be sure.
The reason I want to replace, is because when I took it off the last time I serviced the car, the cap looked very worn, and chunks of what appeared to look like carbon came off the terminals when I went to sand the terminals back.
Black Top 20V 4AGE AE101 BZ-T.
BZG Wagon
Postby Adamal » Mon Jan 30, 2006 11:39 am
Nope, just pull the rotor off, put the new one on. As the shaft is connected to the cam shaft via gears/cogs, it won't budge.
