sa60 struts
sa60 struts
Postby Blackster » Fri Feb 03, 2006 1:07 pm
i have a sa60 celica 1.8ltr
and have some struts from a 2.8ltr celica
same shape but dont know what model
my question is will the brake setup fit on the 2.8ltr struts
from my 1.8ltr model
ie will the brake rotor, pads and calipers fit
thanks
Blackster
Postby suberimakuri » Sat Feb 04, 2006 10:35 pm
sounds like you've got an ma60 and sa60.
check the spacing on the two bolts on the bottom of the strut, should be 89mm on both and so you can just swap whole strut.
suberimakuri
Postby Blackster » Sun Feb 05, 2006 10:14 am
thats spacing is the same
but the ma60 struts dont have brakes
so i wanted to use the brakes from my sa60 onto it
at the moment its just shock spring and a rusty brake rotor
no pads or calipers
thanks
Blackster
Postby suberimakuri » Sun Feb 05, 2006 10:21 am
should be ok, just check the calliper mount...
off memory, aa60 struts have the calliper bolt to the strut, and aa63 struts have the calliper bolt to the backing plate.
heck, it doesn't take long to assemble/dissasemble both :)
suberimakuri
