blacktop in escort
blacktop in escort
Postby escortman » Sat Feb 04, 2006 6:00 pm
ok was gona drop it in my ae82 cuz thought the bluetop was rooted but was jus a blockd pressure pipe
so now hav a 20v blacktop 4age and thought hey y not drop it in the panelvan, so now jus gotta source i think a T50 gb, im thnking of using the 4.4 diff thats already in there( i only care bout mean acceleration screw top end) or how hard to find and fit a hilux diff, arent they lsd
im gona ditch the injection system so dnt hav to change fuel pump etc and jus gona run some siddies get some race cams for a nice lumpy idle and that shud b all of my money gone
escortman
Postby JT » Sat Feb 04, 2006 6:51 pm
4.4 with a T-50 behind a blacktop will see you over 180.
Hilux diff's are plentiful, you just have to find one that is the right width. Some are lsd, some are not.
I'd be keeping the EFI and changing the fuel setup in the car.
JT
Postby atmosports » Sat Feb 04, 2006 6:57 pm
Sounds like a good plan, but a couple of things. If you planing on going with carbs I've got 20V manifolds to suit a blacktop, it would just be a matter of double checking they don't foul on anything else & aren't too long with regards to the carbs or trumpets hitting the inner guard.
What do you plan to do for ignition?? We've done plenty of Zetec/Duratecx & vauxhall 2L motor's into escorts & lotus 7 replicas etc & you strike the same problem either they run a crank angle sensor & no distributor standard or else if they run a distributor type setup it's usually in the wrong place. We've fitted a few Link LEM V5's as ignition only to get round this problem & apart from a few odd problems with some odd coils/ignitors it seems to work pretty well. I'm guessing you could adapt the 4agze crank angle sensor setup to work.
atmosports
Postby evil_si » Sat Feb 04, 2006 11:03 pm
why would you even think to go to carbs, it wouldnt be cheap, and imo a complete waste of a good engine
changing the fuel system is easy.
get a high pressure external fuel pump, put it in line just out from tank, and replace the rubber hoses with high pressure efi hose so they dont burst, you could even spent $30 for a 6meter length of 10mm bundy tube and make a complete new supply line to engine. factory fuel return should suffice
an airtex pump can be had for $120 and will work in either intank or external, available from bnt, supercheap etc
evil_si
Postby vvega » Sun Feb 05, 2006 1:09 pm
atmosports wrote: I'm guessing you could adapt the 4agze crank angle sensor setup to work.
why when the 20v has the same triggers ??
you just remove the cap amd spin up a little cover for it
or am i missing somethin here
v
vvega
Postby escortman » Wed Feb 08, 2006 6:43 pm
yeh im goin to keep it efi and convert the esky, jus 1 prooblem the dizzy is going to foul on the firewall, wat do i do jus run 4 coils?
escortman
Postby vvega » Wed Feb 08, 2006 7:36 pm
yeah get a lem 5 and run wasted spark
see it if will fit in the abck without the dizzy cap and rotor in it
you will find it is quite slim l;ike taht
vvega
Postby spencer » Thu Feb 09, 2006 10:39 am
also youll have to flick the sump around backwards and mod the pick up to fit the escort x-member. also mod the water system because the thermostat housing sticks out more than the dizzy, Ive got some pics of mine somewhere using the rwd water pump
spencer
Postby ROBODISCO_20v » Thu Feb 09, 2006 10:53 am
You may want to have a read of tech reference on this site first to give you a better idea of whats needed to convert a 20v to RWD.
http://www.club4ag.com/
Very cool though that you want to put one in an Escort.
But like the others have said flag the carb idea & stick with the injection. You'll make less power with the carbs, it'll be harder to tune & cost more to set up.
ROBODISCO_20v
Postby pc » Fri Feb 10, 2006 8:56 am
aren't 2 litre cortina engines cheap?, that'll bolt right in wont it?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Leon » Fri Feb 10, 2006 9:47 am
Yes, to a degree (brake master cylinder gets cooked as I recall), but the 20v would be such a lot more fun.
Postby ROBODISCO_20v » Fri Feb 10, 2006 11:08 am
A standard black top will make way more power than a 2L cortina engine. Even If you modify it so its making the same HP the black top will be so much nicer & smoother to drive especially around town
You could alway put the 16v out the ae82 in the escort & then drop the 20v in the ae82. Would be an easier swap coverting the 16v to rwd
Last edited by ROBODISCO_20v on Fri Feb 10, 2006 12:45 pm, edited 1 time in total.
ROBODISCO_20v
Postby escortman » Fri Feb 10, 2006 11:13 am
u also got to modify teh sump as well, i had a pinto motor in my parts van but sold it cause i wud rather work the 1600 kent but yeh now im droppin the blacktop in they hav bout 160 hp and a pinto i htink is jus 100hp so yeh
escortman
Postby Punter » Fri Feb 10, 2006 11:39 am
ROBODISCO_20v wrote:A standard black top will make way more power than a 2L cortina engine. Even If you modify it so its making the same HP the black top will be so much nicer & smoother to drive especially around town
Yep thats totally true, we made 144hp on our old pinto motor,
13:1 compression, big cam, twin side drafts, running on avgas + heaps more.
Was a c#@% to drive on the road, blacktop is a much better option.
Punter
Users browsing this forum: No registered users and 22 guests
