ST185 GT4 Big brake and suspension upgrade ?!
Postby toyoda » Sun Feb 05, 2006 6:47 pm
HI Guys , im currently looking at up grade the suspension and my brake system on my st185 GT4 , dont know where can i get suitable parts in the country and what will be available or will st205 easily to fit onto a st185 , has anyone been through this , any suggestions will be much appreciated :wink:
toyoda
Postby Adydas » Sun Feb 05, 2006 6:57 pm
I belive st205 brakes fit and are what you want.. but getting your hands on them are the problemo. Good Luck
Adydas
Postby toyoda » Sun Feb 05, 2006 7:35 pm
thanks alot man ! :)
toyoda
Postby Malcolm » Mon Feb 06, 2006 12:07 am
to use st205s on the front you need to machine down the rotors to 300mm, and you need to tap a thread into the caliper mount holes.
Also the center hole on the st205 rotors (front only I think) are 1mm larger than the st185 ones, so you need to machine it out a few mm and get a ring made up make it sit nice
Postby toyoda » Mon Feb 06, 2006 5:31 pm
All_Fours wrote:to use st205s on the front you need to machine down the rotors to 300mm, and you need to tap a thread into the caliper mount holes.
cheers for the helpful info man , any chance you know where i can source a set of coilover suspension for st185 at all :)
toyoda
Postby Malcolm » Mon Feb 06, 2006 5:58 pm
no but I can tell you it's a waste of time unless you're making it a dedicated circuit car.
The whiteline "works" handling kit should be everything you need and more
Postby toyoda » Mon Feb 06, 2006 7:19 pm
All_Fours wrote:no but I can tell you it's a waste of time unless you're making it a dedicated circuit car.
:o thanks man , yea im really aming for circuit thats why i really need a good set of coilovers and bigger brakes , thanks heaps for the great help bud :wink:
toyoda
Postby Malcolm » Mon Feb 06, 2006 7:30 pm
Tein do a set for the ST185, so do a few of the other big japanese suspension people I believe. There is also the option to convert your existing struts to coilovers
Users browsing this forum: No registered users and 38 guests
