about racing clutch.....
Postby xx1717 » Tue Feb 07, 2006 10:47 pm
Hi, Im going to buy a cheap 3piece heavy duty racing clutch from my friend. It comes from a damaged 98' curren. Can it be installed on my 94' SS2? Somebody said that it's not good for gearbox, is it ture?
xx1717
Postby Adydas » Tue Feb 07, 2006 10:52 pm
Looks Like a technical question to me :P
Adydas
Postby blackie » Wed Feb 08, 2006 6:22 pm
I dont know about dimensions, if the size of it will fit..
but yes, it will be harsher to your gearbox than a standard clutch
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Postby fangsport » Wed Feb 08, 2006 7:02 pm
personally don't see the point unless you ACTUALLY need one. probably 70% of racing clutches installed in NZ are purely for wank factor.
i don't even bother fitting new std clutches to the rally car, for sure it ain't got 200hp on tap, but second hand ones have never let me down :wink:
fangsport
Postby xx1717 » Thu Feb 09, 2006 2:28 am
Thx...
Just because the clutch is quite new and the price is the same as a normal one. So Im struggle
xx1717
Postby Dell'Orto » Thu Feb 09, 2006 1:07 pm
Depends if its a paddle type clutch or full faced one...a full faced clutch will be fine, though ought to have a heavier pedal feel than standard.
A paddle clutch would be a total waste of time, and will cause quite alot of wear on your driveline.
Postby Leon » Thu Feb 09, 2006 1:15 pm
Are you going to be racing?
The answer to this question is the same as the answer to your "Should I buy a race clutch" question :)
Postby fangsport » Thu Feb 09, 2006 5:54 pm
Leon wrote:Are you going to be racing?
but Leon, streetracers are racers too, they'll be the next group to try and affiliate themselves to MSNZ. so paddle clutches all-round and they'll have a real good time in rush hour traffic :lol:
fangsport
Users browsing this forum: Majestic-12 [Bot] and 8 guests
