rotorchiki69 wrote:they fall apart at any sign of boost ceramic seals or something die after 100,000 kays and no they dnt need to be water cooler
rotorchiki69 wrote:how does that work not saying u dont know ur sh*t bazda just if u shut ya car dowwn after boosting and the turbo is stil spinning with no oil pressure it would damage the seals?
and no u dont need the factory water cooling ive ran heaps of cars without them after doing turbo swaps oviously u just need to blank off the lines
RS13 wrote: worst I can recall, was an SR20 Bluebird, had done 120,000km, that had never been serviced since its' arrival in NZ, snap both cams, we opened the head, it was so blocked up, there was almost zero oil in the head..
True-No-Turbo wrote:RS13 wrote: worst I can recall, was an SR20 Bluebird, had done 120,000km, that had never been serviced since its' arrival in NZ, snap both cams, we opened the head, it was so blocked up, there was almost zero oil in the head..
SR20's have the worst topend oiling system full stop, The oiling rail squirt holes block up all the time. Ive done sh*tloads of em, its just about mandatory to pull the rails out and enlarge the oiling holes. We try and push to run a flush through them before carrying out services etc...
TNT
