4age 20v turbo manifold?
Postby trueno_20v » Sun Feb 12, 2006 9:24 pm
Hey im looking at buying a full stainless manifold from "driven performence" and they are "un branded" im just wondering if anyone has one or knows of anyone that has had problems with them etc..
ADMIN EDIT: signature too large
trueno_20v
Postby Bazda » Sun Feb 12, 2006 9:41 pm
i've seen them, they should be fine, quite nicely made.
Postby Mr Revhead » Sun Feb 12, 2006 11:17 pm
Als a good bloke, he wont deal in dodgy shit :D
Postby trueno_20v » Sun Feb 12, 2006 11:18 pm
Mr Revhead wrote:Als a good bloke, he wont deal in dodgy sh*t :D
What? :?
trueno_20v
Postby Mr Revhead » Sun Feb 12, 2006 11:21 pm
driven performance, aka TWISTD aka Al. not Al with the gay MR2 in chch though :P
Postby trueno_20v » Sun Feb 12, 2006 11:29 pm
Sweet :lol:
trueno_20v
Postby 1598cc » Mon Feb 13, 2006 3:05 pm
xspower ? the collectors looks very similar.
1598cc
Postby JamesM » Mon Feb 13, 2006 3:26 pm
have seen a few of these manifolds that Al has, they are good stuff.
you might want to add some sort of brace in there also for your turbo.
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby aesc » Mon Feb 13, 2006 4:03 pm
Get evil_si to make you up a steampipe one, will be cheaper and he'll customise it for you to suit
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Bazda » Mon Feb 13, 2006 5:09 pm
Ok, Xspower is just a brand name made up by a company in america where they stamp all the stuff they get from taiwan :D.
Most companies get their stuff from exactly the same factory and you can get brand names put on at a little extra cost.
So basically everything on trademe is made is taiwan :) no matter the brand name etc as thats just a a bling stamp on the item that might giv it 10hp.
All the recent manifolds that have been coming from taiwan have been mint, havent heard of them break yet. But when you mount up your turbo and when people do downpipes sometimes it a tight fit and there is no movement in the exhaust system (need flexi) when the engine needs to rock back and fourth this resulting is the manfolds breaking.
IMO this is where people go wrong and their taiwanese manifolds break.
Postby 1598cc » Tue Feb 14, 2006 2:23 pm
Bazda wrote:Ok, Xspower is just a brand name made up by a company in america where they stamp all the stuff they get from taiwan :D.
ive never seen a xspower/taiwan or what not manifold not break; personally seen 2 rb20det one with just a downpipe, sr20det, b series honda manifolds break/crack, all around the collectors. you should expect a stainless manifold to break on a east-west engine without a flexi, and although its recommended , ive run alot of steampipe manfiolds without a flexi with no problems, not the best idea tho.
has anyone actually seen one of these taiwan manifolds NOT cracK?.
1598cc
Postby JamesM » Tue Feb 14, 2006 2:35 pm
just look at the design.. big looping tubes.. they need a brace.. and flexi.
Team Megasquirt
1984 AE86
JamesM
Postby Bazda » Tue Feb 14, 2006 6:42 pm
I have heaps of mates with the taiwanese manifolds and they havent broken, they all use a well setup exhaust system putting the least amount of stress on it.
Of course steam pipe isnt going to break, its steam pipe, stainless is much more fragile, even when you get proper ones made by performace shops they also break with out the correct procedures.
Herbert fabrication made this bling as one for this BMW out of stainless it costed like $7g and they friken broke!! twice!, thats just what you get with stainless when not enough bracing is added and dampering.
Postby trueno_20v » Tue Feb 14, 2006 8:08 pm
On approx 7psi you guys think ill need to change anything with the fueling ,pump, FPR, injectors etc?????????
trueno_20v
Postby Caveman » Wed Feb 15, 2006 9:18 am
trueno_20v wrote:On approx 7psi you guys think ill need to change anything with the fueling ,pump, FPR, injectors etc?????????
You will have to change pretty much all of those :lol: Just have a little search. on 300cc injectors you'll be limited to about 200HP :( plus you'll need a new computer to read the boost.
You could always go rangi styles, 2bar map sensor plus 600cc injectors. Will work but timing will advance. advance timing + high compression + boost = dead engine
Just do it properly. turbo + computer + decompression. Its how its always been done and it works best. idealy forged pistons would be suited but you could get away with the 20V cast flavour, it'd be flaky though.
oh and these heaps of other crap like intercooler, plumbing, etc but you can sort those out as you come across them :D
Caveman
Postby Ako » Wed Feb 15, 2006 10:18 am
Can someone please, for the sanity of everyone who reads the tech section, write up an FAQ of how to turbo a 4AGE, with PRICING of everything?
Its not something you want to do on the cheap, unless you like rebuilds.
Yes you need a fuel pump.
Yes you need injectors.
No the stock ECU won't like it.
List goes on.
Ako
Users browsing this forum: No registered users and 29 guests
