Can i use a celica 2.2l gearbox on a 2.0l?
Postby 1loose_mr2 » Mon Feb 13, 2006 8:13 pm
both cars are the same year (1990) but different size engines,does anyone know if theyre the same gearbox(manual)? :? its a gtr
1loose_mr2
Postby Malcolm » Mon Feb 13, 2006 8:14 pm
yes it should fit fine.
Postby 1loose_mr2 » Mon Feb 13, 2006 8:18 pm
sweet,how hard is it to change.got the basic tools and knowledge.any tips
1loose_mr2
Postby Malcolm » Mon Feb 13, 2006 9:56 pm
it's pretty easy, when you've got the old gearbox out put it next to the new one and have a look at them side by side to see if there's anything different that needs to be swapped from one to the other.
make sure you keep track of where everything goes, try not to lose any bolts etc. Having a friend to help will be useful because if you haven't done one before, two heads are always better than one (unless your mate is retarded), and lining up the gearbox with the clutch can be tricky and if you're not experienced you might need someone to help support the weight of the box.
Postby AJz » Tue Feb 14, 2006 12:56 am
yes i can confirm you can as they used the same box, im on my 2nd :twisted: which i managed to get from a NZnew 2.2lt celica. so yes it would work fine
I had vtax :(
AJz
