AE101-AE111 S/S Shocks??
Postby redline racer » Mon Feb 13, 2006 10:15 pm
Hey, I have done a search and established the springs are interchangable between the AE101 and AE111 Super strut models but are the shocks?
Cheers.
redline racer
Postby bad20v » Tue Feb 14, 2006 10:35 am
AFAIK, yes they are interchangeable, but I'm not 100% sure that the brakeline brackets are in the same position, but that shouldn't be too much of a problem.
If you are getting second-hand units then get the S/S knuckle joints checked out before you fit the front shocks to your vehicle as they could be faulty or worn out and you don't want to take them out again to fix them later down the track.
8)
Thank-You.
bad20v
Postby Mr Revhead » Tue Feb 14, 2006 11:57 am
yes they are interchangable. TRD list the same p/n for both
cant be arsed checking the stock numbers :P
Postby redline racer » Tue Feb 14, 2006 4:37 pm
Cheers Guys 8)
redline racer
