by bad20v » Tue Feb 14, 2006 10:35 am
AFAIK, yes they are interchangeable, but I'm not 100% sure that the brakeline brackets are in the same position, but that shouldn't be too much of a problem.
If you are getting second-hand units then get the S/S knuckle joints checked out before you fit the front shocks to your vehicle as they could be faulty or worn out and you don't want to take them out again to fix them later down the track.
Thank-You.
