external wastegate / mr2
Postby fat-boy » Sat Feb 18, 2006 12:48 pm
i got a 90 mr2 gt.
twin entry turbo.
has anyone fitted an external to a standard twin enty manifold b 4 ?
i was just concerned as 2 ports are seperate to the other 2 ports on the manifold and cause cause problems trying to plumb it up.
also how much boost can a 3sgte safly hold ?
cheer
tony
"F T 50"
fat-boy
Postby Malcolm » Sat Feb 18, 2006 1:00 pm
why do you need and external? I hope you're not just doing it for sound - screamers suck arse
Postby Akane » Sat Feb 18, 2006 1:20 pm
Don't listen to All_fours, external owns.
And you have to mount the external right ontop of where all 4 of the channels joined if you want to have it "better"
Postby fat-boy » Sat Feb 18, 2006 1:21 pm
because i can i was askin howto plumb it not for peopes opinions.
"F T 50"
fat-boy
Postby fat-boy » Sat Feb 18, 2006 1:27 pm
Akane wrote:Don't listen to All_fours, external owns.
yea but the problem is they dnt join up. 2 chanels go to teh left entry and the other 2 chanels so to rite entry. hence teh twin entry turbo.
so wat shal i do ?
weld a tube on one chanel and a tube on the other chanel and join then together then into the wastey ?
"F T 50"
fat-boy
Postby Adamal » Sat Feb 18, 2006 1:51 pm
If you're going to be sticking with the CT26, then don't even bother. It'd be a waste of money to mod the standard extractors and you wouldn't get any gains. Boost controlling can be done on an internal wastegate anyway, if thats what you're thinking.
Postby fat-boy » Sat Feb 18, 2006 1:58 pm
Adamal wrote:If you're going to be sticking with the CT26, then don't even bother. It'd be a waste of money to mod the standard extractors and you wouldn't get any gains. Boost controlling can be done on an internal wastegate anyway, if thats what you're thinking.
well i already have the external in the garage and just aquired a new mr2 so i thaught id put it to gud use.
"F T 50"
fat-boy
Postby Adydas » Sat Feb 18, 2006 2:20 pm
you could sell it on trade me? put the money towards something else, Electronic boost controller etc? Idea anyway.
Ill be using an external with the unit i picked up but thats as it dont come with a internal WG, just uses some kinda adapter plate between the manifold and the turbo.
To be honest if i could swap and use internal i would, so id back the sell it and get a wicked electronic boost controller instead.
Adydas
Postby fivebob » Sat Feb 18, 2006 2:23 pm
But that's not a gud(sic) use for an external gate. It's a complete waste of time, effort and money... Oh wait you weren't looking for opinions, well sucks to be you then because you're going to get them :roll:
Postby Chickenman » Sat Feb 18, 2006 8:11 pm
You should probably sell the MR2 before you ruin it... and buy a rotary.
:D
Yeah, yeah. scratch one MR2 for Toby
Baby Jesus
Chickenman
I Am The Walrus!
Postby strx7 » Sat Feb 18, 2006 9:40 pm
ditch the CT26 on Trade-me and put a TD05H/TD06 MSE turbo on it with your external wastegate and fabricate up a new exhuast manifold
Postby Adydas » Sat Feb 18, 2006 9:42 pm
what about some new cams and pistons while ya at it :P
Adydas
Postby Akane » Sun Feb 19, 2006 7:13 am
plant it right ontop of where the 2 joins!
Postby GT4 20 » Sun Feb 19, 2006 7:19 am
Come on lads, be nice to fat-boy. If he doesn't go through the pointless exercise of putting on an external wastegate, how can he brag about it to his mates :wink: :lol:
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby vvega » Sun Feb 19, 2006 1:44 pm
since none here aside from akane has attualy even tried to answer your question.......
technically you are suposte to have 2 externals
cuting and joining the trac'sof the manifold completely viods the whole idea or twinscroll
but yes if you only have one and do not care about this use a hole saw and get a bit of steam pipe welded in there with a TIG(you have to use tig)
you also have to decoke the underside of teh weld as as teh weldpool will petatrate if it touchs carbon it will absorb it and make teh weld(with cast iron) go crystaline(brittle) and porus(wont seal properly)
v
vvega
Postby vvega » Sun Feb 19, 2006 1:52 pm
so wat shal i do ?
no you cut a hole in the middle and grind out the center
thats what he ment by his post
vvega
Postby fat-boy » Sun Feb 19, 2006 2:45 pm
so wat shal i do ?
ohh cheers for that man now i get it now.
"F T 50"
fat-boy
Postby Akane » Sun Feb 19, 2006 6:02 pm
who cares anyway, cars suck.
Postby fat-boy » Sun Feb 19, 2006 7:03 pm
Akane wrote:who cares anyway, cars suck.
haha agreed. :lol:
"F T 50"
fat-boy
Postby Ako » Mon Feb 20, 2006 9:20 am
The same issue happens with evo 4 onwards with their manifolds.
Method a few people use to avoid touching the manifold - port out the internal wastegate to as big as possible, remove the flapper totally, then have the external gate mounted right there, of the flange you'd bolt to your turbo. Means you make a new downpipe, but meh, thats a bonus anyway.
To the rest of you - no need to have a go at the guy. I'm one of those people who like the sound of an external, just like a stupidly loud BOV. So what if it doesn't have any real gains - neither does the widebody kit / big wheels / painted rocker cover you have.
Ako
Users browsing this forum: Bing [Bot] and 14 guests
