Akane wrote:Don't listen to All_fours, external owns.
And you have to mount the external right ontop of where all 4 of the channels joined if you want to have it "better"
Adamal wrote:If you're going to be sticking with the CT26, then don't even bother. It'd be a waste of money to mod the standard extractors and you wouldn't get any gains. Boost controlling can be done on an internal wastegate anyway, if thats what you're thinking.
fat-boy wrote:Adamal wrote:If you're going to be sticking with the CT26, then don't even bother. It'd be a waste of money to mod the standard extractors and you wouldn't get any gains. Boost controlling can be done on an internal wastegate anyway, if thats what you're thinking.
well i already have the external in the garage and just aquired a new mr2 so i thaught id put it to gud use.
fat-boy wrote:Akane wrote:Don't listen to All_fours, external owns.
yea but the problem is they dnt join up. 2 chanels go to teh left entry and the other 2 chanels so to rite entry. hence teh twin entry turbo.
so wat shal i do ?
weld a tube on one chanel and a tube on the other chanel and join then together then into the wastey ?
vvega wrote:fat-boy wrote:Akane wrote:Don't listen to All_fours, external owns.
so wat shal i do ?
no you cut a hole in the middle and grind out the center
thats what he ment by his post
