battery into boot... (no not another How do i do i)
Postby Infinite » Sun Feb 19, 2006 9:18 pm
Ok,
So you have moved your battery to the boot, Put in some heavy duty starting cable's But... What about this "over loading" of the earth and these circle earth systems? u see for 500 bux... are u better to bring a cable back to the front of the car for a earth to? and then also bridge off that with a circle earth system?. Fell free to prove me wrong just wana get some opinions...
Lots
Infinite
Postby Lloyd » Sun Feb 19, 2006 9:26 pm
Move the battery, put the negative to a decent chassis earthing type place in the boot and it'll be fine
Postby Infinite » Sun Feb 19, 2006 9:29 pm
so the hks circle earth system is bs?
Lots
Infinite
Postby Alex B » Sun Feb 19, 2006 9:32 pm
lol yes, $350 for a whole lota 8 gauge wire is BS.
Postby Infinite » Sun Feb 19, 2006 9:36 pm
never said i was gona buy there sht :P im sure just making your own is going to do the job
Lots
Infinite
Postby Si » Sun Feb 19, 2006 10:20 pm
make sure you have very good earths all round
i recall docha's car with the battery in the boot.....
link went frappy then injectors went frappy and filled cyls with petrol...
Current: , '96 SubaruImpreza
Si
Postby Stealer Of Souls » Mon Feb 20, 2006 9:15 am
Directly wired earths (or this circle thingy) will always give a better earth than direct to chassis....
But the difference is 5/8s of F all.
Renewing all the factory earths with new (and if poss bigger) cable in a very old car may help.
Making some additional links may improve earthing on old cars too. Like additional link between gearbox and engine, engine and chassis, lighting systems to battery, and head to block. But again, gains are small, costs are big. Really only good as back up protection against worn old cables...
'86 AE85.5 Levin
Stealer Of Souls
Postby barryogen » Mon Feb 20, 2006 11:15 am
Stealer Of Souls wrote:Directly wired earths (or this circle thingy) will always give a better earth than direct to chassis....
in my old car(Subaru Legacy) it had it, I asked the question, got the same answers you have, so removed it, then I got weird hissing in the stereo, and hesitation under heavy load, connected it back up, and it all went away... not sure if the Subby just had crappy wiring or ont, but it made a difference in that car.
barryogen
2ZZ Guru in training
Postby Stealer Of Souls » Mon Feb 20, 2006 12:02 pm
At a guess...
Stereo hiss is an earth loop... Strange for the engine bay earths to affect the stereo. But not impossible. It could also have been that the engine bay earths were acting as a noise shield on the ignition system.
The hesitation at high load sounds like the ignition system didn't like the removal of the earth leads...
Well then. I guess there is more to this that first thought.
I would still say that, if the car goes fine an earth loop system would still do not a lot. But the only way to know for sure is to try...
'86 AE85.5 Levin
Stealer Of Souls
Postby sergei » Mon Feb 20, 2006 12:24 pm
The main problem whith battery in the boot, that the main earth wire (wich usually connects battery to gearbox) becomes dissconnected and the all current goes through smaller wire which is not really enough to supply starting current (starter will turn slower then usual).
A had real bad experience of smoking up the loom under the dash..
Make shure you connect the gearbox to different points on chassis with a couple of fat wires, and also connect head to chassis as well, that should take care of ignition RF noise.
Postby fangsport » Mon Feb 20, 2006 12:31 pm
Sergei, why was the battery-> gearbox earth not reconnected to chassis??
as long as the battery (-) is bolted to a good clean piece of chassis and the main engine/gearbox-> chassis is the same, then there should be know dramas.
fangsport
Postby sergei » Mon Feb 20, 2006 12:39 pm
Generally the earth is connect to both chassis and battery, but the battery cable is much fatter then the one goes to chassis, as battery being moved the fat wire goes to nowhere (or in some cases it is conected to thin wire, thus not helping) and all current has to go through the thin wire and wiring loom grounds, which will divide load and even 50A going through wiring loom might smoke it up (especially considering the wires getting hotter and resistance being increased thus creating even more heat).
Postby Infinite » Mon Feb 20, 2006 7:28 pm
i think im going to run 2x fat motha f cables back to the front one for + one - then setup a nice block for taken a few more earth's off... people spend more money on burn out tyres than what this cost's so why not :) least this aint use it once and throw it away
Lots
Infinite
Postby Loudtoy » Mon Feb 20, 2006 8:39 pm
sergei wrote:Generally the earth is connect to both chassis and battery, but the battery cable is much fatter then the one goes to chassis, as battery being moved the fat wire goes to nowhere (or in some cases it is conected to thin wire, thus not helping) and all current has to go through the thin wire and wiring loom grounds, which will divide load and even 50A going through wiring loom might smoke it up (especially considering the wires getting hotter and resistance being increased thus creating even more heat).
Um so why didn't you just connect the old wire that went to that battery to the chassies in some way?? Thats what most people do and i'm guessing thats what fangsport is trying to get at here as well (why aren't you like most people)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby fangsport » Mon Feb 20, 2006 8:43 pm
Loudtoy wrote:Um so why didn't you just connect the old wire that went to that battery to the chassies in some way?? Thats what most people do and i'm guessing thats what fangsport is trying to get at here as well (why aren't you like most people)
yip.
fangsport
Postby sergei » Mon Feb 20, 2006 8:45 pm
As I was not aware that the second ground was not fat enough.
I assumed that there should be at least 2 fat ground wires just in case, one going to battery and another going to chassis, but there was only 1 fat going to battery....
Postby Infinite » Mon Feb 20, 2006 8:52 pm
because when u turn the headlights on full the dash dim's and relying on a simple grond that goes to the boot is like using a crapy little bolt that holds the ground wire onto a truck chassi *bang* and it wont be consistnt between the front of the car and the rear so why not do it correctly?
Lots
Infinite
Postby fangsport » Mon Feb 20, 2006 8:53 pm
Fangi wiring goes like this: battery in back seat cavity (rally car)
main + through master to starter and accesories via fuses and relays.
main - to chassis by battery. heavy earth chassis > block, light earth chassis > rocker cover also earthed via alternator. accessories earthed via dash, firewall etc.
for a road car:
Main + to fusable links/starter.
main earth to chassis,old battery earth to engine via chassis.
i'm sure a auto sparkie can confirm or deny, but i fail to see the need for 2 cables from battery to the former battery location.
fangsport
Postby Malcolm » Mon Feb 20, 2006 9:10 pm
definitely no need for running an earth back to the front of the car, the chassis can carry more current with less resistance than the wire you're gonna use (unless you are stealing it from buried high voltage cables)
Postby Si » Mon Feb 20, 2006 9:14 pm
All_Fours wrote: (unless you are stealing it from buried high voltage cables)
hey, it happens, south africa is well known for it......
rip up cables and sell em for scrap copper!
Si
