4age - 4-2-1 or 4-1 extractors?
Postby RickGT » Mon Feb 27, 2006 10:51 am
so im geting a set of extractors, what should i go for?
what are the coby 1s like an also these rage 1s ive neva herd about
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby Mr Revhead » Mon Feb 27, 2006 11:16 am
what mods does your engine have?
Postby RickGT » Mon Feb 27, 2006 11:31 am
pod filter, just gona go for 20v extractors and fit them up, any1 got ne
EP91 Glanza V
RickGT
Postby Mr Revhead » Mon Feb 27, 2006 11:58 am
ah yep, 20v ones will do 8)
Postby RomanV » Mon Feb 27, 2006 12:12 pm
I'd only ever go for 4-2-1.....
4-1 just seems like it's done for cost effectiveness, more than anything.
Postby Punter » Mon Feb 27, 2006 12:14 pm
4-1 has its advantages, none at all for a road car though.
Punter
Postby Santa'sBoostinSleigh » Mon Feb 27, 2006 12:28 pm
Punter wrote:4-1 has its advantages, none at all for a road car though.
what about for my 20v track/club car?
just the standard 20v ones be ok?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Mr Revhead » Mon Feb 27, 2006 12:33 pm
yep.
4-1 suit peak hp.
and on a basicly stock production based engine thats no use.
Postby Punter » Mon Feb 27, 2006 1:09 pm
Santa'sBoostinSleigh wrote:what about for my 20v track/club car?
To be honest i'd just stick with the standard ones, and spend the money elsewhere. The gain you would get wouldn't be that big.
Punter
Postby KinLoud » Mon Feb 27, 2006 10:17 pm
If you have a close ratio gearbox and a full race motor then go 4:1
Otherwise you might find that you end up with no torque when you change into the next gear because the motor is so peaky.
HOWEVER...
If you are getting extractors made you could do what I did when I put a gen3 3sge into my racecar. I got the extractors made in 3 seperate pieces with slip joints and brackets so they can be bolted together.
primary - 1 x flange with 4 pipes
secondary - 2 x 2 into 1 pipes that fitted onto the 4 pipes
collector - 1 x 2 into 1 pipe that fitted onto the end of the 2 2into 1 pipes
So I have a 4:2:1 system but if I want to in the future I can get a 4 into 1 collector built and fit it onto the end of the 4 pipes.
I set it up so I can put pipes inline to extend the primary pipes or extend the secondary pipes to tune the extractors if I ever had the time.
Ken
Ham
021 408 863
Postby RickGT » Tue Feb 28, 2006 12:54 am
do 16v colectors fit the 20v extractors or nah? i supose the 20v ones are better anyway, am i right?
EP91 Glanza V
RickGT
Postby RedMist » Tue Feb 28, 2006 8:09 am
4-1 is old school peak power. Modern 4-2-1 extractors can have (if designed correctly) the same peak power (in most cases more) than a 4-1 extractor, howerver has a stronger mid range.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
