Im thinking of removing the power steering from my levin.
Is it possible to remove the PS/AC belt and run around a while without power steering to see what it will be like, and if it will be worth it? Will this damage the steering rack?
Thanks
fx gt wrote:FXGTV wrote:Why would you want to remove your ps?
so the engine dosnt have as much restrection
race spec!
ATAl wrote:The ps rack without the ps connected is a lot heavier than the non ps rack.
I've done the non ps conversion on my levin and and the steering weight isn't an issue - however the non ps rack is a lot slower ratio, this can be annoying sometimes.
