No power steering.
No power steering.
Postby Caveman » Tue Feb 28, 2006 7:33 pm
Im thinking of removing the power steering from my levin.
Is it possible to remove the PS/AC belt and run around a while without power steering to see what it will be like, and if it will be worth it? Will this damage the steering rack?
Thanks
Caveman
Postby FXGTV » Tue Feb 28, 2006 7:52 pm
Why would you want to remove your ps?
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby fx gt » Tue Feb 28, 2006 8:12 pm
FXGTV wrote:Why would you want to remove your ps?
so the engine dosnt have as much restrection :)
race spec!
fx gt
Postby Caveman » Tue Feb 28, 2006 10:13 pm
race spec!
Well it would be more 'race spec' if I could use a 3' dump pipe instead of the 2' which will fit now.
Does anyone know?
I know I can relocate the pump etc, etc, etc.
What I want to know is if I can 'simulate' non-power steering just by taking off the belt and if this will do any damage. If its a pain in the arse without power steering ill look at relocating the pump, etc, etc, etc.
Oh and I also realise that the non-power steering cars use different steering links.
Caveman
Postby ATAl » Tue Feb 28, 2006 10:18 pm
The ps rack without the ps connected is a lot heavier than the non ps rack.
I've done the non ps conversion on my levin and and the steering weight isn't an issue - however the non ps rack is a lot slower ratio, this can be annoying sometimes.
ATAl
Postby Steve123 » Tue Feb 28, 2006 10:29 pm
As you have modified the steering, you may be asked to get a cert too.
Steve123
Postby matt dunn » Tue Feb 28, 2006 10:41 pm
ATAl wrote:The ps rack without the ps connected is a lot heavier than the non ps rack.
If you just take off the pump, it will be heavy as hell as you will have to pump the oil through the rack by hand.
Either relocate the pump, or fit a non p/s rack.
Postby Caveman » Tue Feb 28, 2006 10:44 pm
Ok thanks for the info. Does anyone know a bolt in replacement for an ae92. will ae82 fit? Ill go for a scab a pick-a-part soon 8)
Caveman
Postby Mr. Mainstream » Wed Mar 01, 2006 8:18 am
I removed tghe power steering from my 2nd FWD 323, i used the NON-P/W rack and didnt have too much trouble
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby MrOizo » Wed Mar 01, 2006 8:25 am
there must be a 'budget' version of the AE92's at some where like pick a part.
maybe even a AW11 rack might fit.. not sure but its always a possibility.
MrOizo
Toyspeed Legend
Postby Caveman » Wed Mar 01, 2006 9:11 am
Ill probably look around for an ee90 or similar. Thanks for the info guys
Caveman
Postby Leon » Wed Mar 01, 2006 9:39 am
My EE90 (NZ new) has non p/s so the rack does exist. Although, bear in mind it will probably also involve using the non p/s rack ends etc, so check out carefully what bits you will need.
The steering is pretty damn heavy in the EE90 when the tires start wearing, even on 13" biscuits, so bear that in mind. Parking is going to be a pain.
Postby ATAl » Wed Mar 01, 2006 5:47 pm
ee90 steering rack fits fine, but you need to grab all the universals connecting the steering rack to the steering wheel and also the cover for where the steering rack joins the universals as all these parts are different.
ATAl
Postby soopachargen » Wed Mar 01, 2006 8:51 pm
theres some good info on nzhondas and honda tech about running "closed loop" powersteering, basically u remove the belt and resoviour and loop the hoses with a breather to let out excess air and it keeps the rack lubed... dunno if this would work with a toyota tho.
Could i use a bz rack in my ae91 to get faster steering?
When in doubt, down and out.
soopachargen
Postby $CENSLS1$ » Thu Mar 02, 2006 9:23 am
I ran my EF Civic (now dead) with out p.s when it blew it's pump apart.Just took the belt off and drove round without it for about 3months.Didn't seem to do any damage to the rack...Feels absolutly wicked with it off on a p.s car without the pump.LOTS of feedback through the steering and nice quick ratios ;)
However...don't get yourself into tight situations or you will get stuck...Lots of elbow grease when moving slow and parking...Well worth it tho ;)
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
