Oooh I did something dumb
Postby Ako » Fri Mar 03, 2006 9:23 am
I have a nagging feeling my MR2 keys may have gone to the dump :lol:
I'm not worried about getting the car started - but is there a way for me to break / disable the steering lock so I can tow the car? Its moving to a new home and I wont have time to go hunting round the wreckers for a complete set of locks + key before the cars getting shifted!
Ako
Postby Malcolm » Fri Mar 03, 2006 9:45 am
if you have a pipe wrench you can break the entire ignition barrel off and that will get rid of the steering lock (and you can unscrew the switch from the back and start it with a screwdriver)
I will have a steering column/ignition barrel and hopefully some keys shortly if needed also.
Postby fivebob » Fri Mar 03, 2006 12:26 pm
The key number is stamped on the lock barrel in the passengers door. Give that number to a Toyota dealer and they can cut you a new one :wink:
Postby Adamal » Fri Mar 03, 2006 2:48 pm
You'll find that a lot of locksmiths can also do this.
Alternativly, you can give Toyota your chassis code and they should be able to give you the keycode (If you can't find it on the barrel.)
Postby Al » Fri Mar 03, 2006 4:49 pm
fivebob wrote:The key number is stamped on the lock barrel in the passengers door. Give that number to a Toyota dealer and they can cut you a new one :wink:
Or the locksmith down Sandyford Street. They will only charge around $7 a key....god knows how much the stealership would charge :)
Al
Postby Ako » Fri Mar 03, 2006 5:16 pm
You guys are legends.
I was gonna go home and start breaking sh!t :lol:
Ako
Postby Malcolm » Fri Mar 03, 2006 5:50 pm
breaking it is still far more satisfying than doing what they suggested :P
Users browsing this forum: No registered users and 29 guests
