LINK for standard 4age - good idea?
Postby l1ttle_d3vil » Wed Mar 15, 2006 3:07 pm
i'm not too familiar with LINK computers etc, basically I want to know is there any purpose or advantage (particularly performance-wise) in getting a plug-in link for a standard 4age bluetop engine. the engine hasn't had any other sort of mods, it is n/a.
i have had people tell me that a link would make my engine alot quicker even though it is non-turbo but i've also had people saying no it won't. it is basically an intercept link which allows you to adjust fuel ratios.
good idea or a waste of money? :?:
Re: LINK for standard 4age - good idea?
Postby barryogen » Wed Mar 15, 2006 4:24 pm
l1ttle_d3vil wrote:good idea or a waste of money? :?:
could be both.
good idea if ou plan on changing things that need a big change in fuel/other engine management.
waste of money if you don't plan on making any changes in future.
barryogen
2ZZ Guru in training
Postby soopachargen » Wed Mar 15, 2006 4:28 pm
i dont believe u can get a plug-in link for the 4age...
When in doubt, down and out.
soopachargen
Postby l1ttle_d3vil » Wed Mar 15, 2006 4:43 pm
sorry, probably used the wrong term. i think its wired up through the standard ECU and just modifies the information that it recieves and passes on to the ECU or something.
I don't plan on doing anything to the engine any time soon; definitely nothing major like turboing it or anything.
Postby Ako » Wed Mar 15, 2006 5:20 pm
For the money you'll be spending, don't bother. If your not planning on working the engine, you could much much better use the money on beer, women, or similar.
Ako
Postby RedMist » Wed Mar 15, 2006 7:19 pm
l1ttle_d3vil wrote:sorry, probably used the wrong term. i think its wired up through the standard ECU and just modifies the information that it recieves and passes on to the ECU or something.
the old 'intercept link' ??
I wouldnt think it would give you any performance increase on a standard engine. In fact with many hours tuning, you may be able to get stock performance.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby vvega » Wed Mar 15, 2006 7:58 pm
its only funny cause its true :D
v
vvega
Postby escortman » Wed Mar 15, 2006 8:33 pm
is he talking bout a piggyback computer?
escortman
Postby crnkin » Fri Mar 17, 2006 5:34 pm
Ako wrote:you could much much better use the money on beer, women, or similar.
or both. at the same time...
deaf_homo "currrently yes"
crnkin
