ke70 brake upgrade
ke70 brake upgrade
Postby Scheme » Sun Mar 19, 2006 3:21 pm
Slotted an older 16v 4a-ge in my ke70, I'm guessing I'll at least need to upgrade the front brakes, move off the solid rotors at least... Best way to go ae86 struts?
I'm guessing the rear drummies wont really need replacing..
Scheme
Postby wde_bdy » Sun Mar 19, 2006 5:08 pm
Unless you are throwing it at a track regularly I wouldn't waste your time with an upgrade, you haven't really added a lot of weight into the car. Decent Mintex pads from Race Brakes and new slotted rotors will be plenty. If you do have fade problems add some ducting.
Callum
wde_bdy
Postby gepsk8 » Sun Mar 19, 2006 6:42 pm
ke70 wagon brakes are bigger for a little bit of an upgrade
gepsk8
Postby Scheme » Sun Mar 19, 2006 7:15 pm
oh, real? Yea it is a ke70 wagon. I'll chuck in some good pads then, I would of thought an upgrade would be required for cert... I'll just reseal and give the standard calipers a good clean out. I attempted to find some new rotors for it, just new solid ones, tried a couple of places and they couldnt come up with anything. Any suggestions where to find?
Scheme
Postby fangsport » Sun Mar 19, 2006 7:46 pm
purple_beasty wrote:Unless you are throwing it at a track regularly I wouldn't waste your time with an upgrade, you haven't really added a lot of weight into the car. Decent Mintex pads from Race Brakes and new slotted rotors will be plenty. If you do have fade problems add some ducting.
Callum
what he said. i have a 3T in a TE71 club/rally car with std KE70 front brakes, but fitted half decent pads. never had an issue with slowing down, unless it's too little, too late!!
fangsport
Postby wde_bdy » Mon Mar 20, 2006 12:00 am
http://www.racebrakes.co.nz/
They will be able to supply the slotted rotors (don't know price) and Mintex pads (just over $200). Although it may sound not that cheap, if you were to do a swap you would need to buy decent pads and probably new rotors anyway.
Callum
wde_bdy
Postby Dell'Orto » Mon Mar 20, 2006 10:31 am
I bought DBA slotted rotors for my sedan (still solid though :cry:). KE70 2 door wagons have 10mm larger rotors, which might be an option, though I'm not sure what tweaking you'd have to do to make them fit.
I think Racebrakes can do upgraded material for your drums too?
Postby l1ttle_d3vil » Mon Mar 20, 2006 1:35 pm
Scheme wrote:I would of thought an upgrade would be required for cert...
nope not at all, not for a standard 4AGE anyway. I certed my ke35 / bluetop 4age on the standard brakes with no problems.
