Slotted an older 16v 4a-ge in my ke70, I'm guessing I'll at least need to upgrade the front brakes, move off the solid rotors at least... Best way to go ae86 struts?
I'm guessing the rear drummies wont really need replacing..
purple_beasty wrote:Unless you are throwing it at a track regularly I wouldn't waste your time with an upgrade, you haven't really added a lot of weight into the car. Decent Mintex pads from Race Brakes and new slotted rotors will be plenty. If you do have fade problems add some ducting.
Callum
Scheme wrote:I would of thought an upgrade would be required for cert...
