blowing up a p.o.s 4af
Postby touge rolla » Tue Mar 21, 2006 9:02 pm
can anyone think of any reasons (like safety) why i shouldn't finish off my soon to be binned 4af by parking it in neutral putting a brick on the accelerator and seeing how long it will go for???
touge rolla
Postby Lloyd » Tue Mar 21, 2006 9:08 pm
Stand back... take pics/video
Postby Jazza » Tue Mar 21, 2006 9:08 pm
Wouldnt it be easier to do it near a cliff and claim insurance? :P
Jazza
Postby touge rolla » Tue Mar 21, 2006 9:13 pm
only have 3rd party :( should i have mentioned i want to use the rest of the car?
touge rolla
Re: blowing up a p.o.s 4af
Postby bluemaumau » Tue Mar 21, 2006 9:13 pm
touge rolla wrote:can anyone think of any reasons (like safety) why i shouldn't finish off my soon to be binned 4af by parking it in neutral putting a brick on the accelerator and seeing how long it will go for???
probley aint gona get insurance for blowing up your cars engine next to a cliff... :lol:
Postby Bling » Tue Mar 21, 2006 9:17 pm
i'll take it off ya hands :lol: :lol:
go on, ya know u would get more satisfaction from giving it to me 8)
Postby strx7 » Tue Mar 21, 2006 9:38 pm
if you drill a hole in the radiator hose it'll go for 15-20 mins before it simply runs outta compression from being cooked. Speaking from experience, toyota's are the sadest things to do brick on accelerator blow ups with. they never throw rods, they never drop their guts in a big way, they just get so bloody hot they slowly come to a halt, and not from seizing either.
Postby Si » Tue Mar 21, 2006 10:11 pm
have a play with the timing and everything else you can adjust :)
thinners into the carb, changing spark leads around, putting the hose onto the dipstick hole and filling the block with water
use your imagination :)
Current: , '96 SubaruImpreza
Si
Postby CozmoNz » Tue Mar 21, 2006 10:16 pm
fill the engine with petrol + oil mix..
explosive performance :D.
Rayne For President!
CozmoNz
Postby YeMs » Tue Mar 21, 2006 10:52 pm
strx7 wrote:if you drill a hole in the radiator hose it'll go for 15-20 mins before it simply runs outta compression from being cooked. Speaking from experience, toyota's are the sadest things to do brick on accelerator blow ups with. they never throw rods, they never drop their guts in a big way, they just get so bloody hot they slowly come to a halt, and not from seizing either.
haha yeh and specifically with 'K' motors, give it half an hour and start it up again.
yeh iv seen a few motor blows.. and they all seem to just b motor, well.. stops? just heat siezed.
hrmm, see how lean u can get it? try run it on start ya bastard? um pee on it? throw bananas at it while valve bouncin it? think, be resourcefull.
Your local Hybrid Elite tech
YeMs
Postby ollieboy » Tue Mar 21, 2006 11:26 pm
YeMs wrote:um pee on it?
Bad idea, did it once, smells really bad and makes you wanna hurl.
Put gravy in the sump and pea soup in the radiator so they look like oil and antifreeze respectively.
ollieboy
Postby strx7 » Tue Mar 21, 2006 11:38 pm
Working at a dismantlers we religiously blow up a few cars each christmas. Last year we did a GX60 cressida with 1GEU, sat on 8000rpm for 15 mins before finally running outta compression. Could still crank it with the starter but sounded like the plugs weren't at home. a few years ago we did an SX70 Cresta with a 2SE rwd. It got so hot the front cambelt cover was half melted off and the dizzy got so hot the area around the locator pins/screws in the cap melted the timing altered so much it stopped.
Honda's are the best for blow ups, pretty much guaranteed to put at least 1 rod thru the block, will then run on 3 cylinders and put a 2nd thru the block.
Postby bluemaumau » Tue Mar 21, 2006 11:38 pm
im just putting this out there,
the 4afe has to be up there with the strongest engines, 8)
i thrash mine on a daily basis and it never misses a beat, :P
and its done 345xxxkms never had to replace anything internal in the head block or gbox, and ive had it since 260xxxkms. 8O
i wouldnt mind seeing a 4afte, that would be kool 8)
Postby strx7 » Tue Mar 21, 2006 11:46 pm
........4AFTE, if ya killed it you can grab another 4AFE and abuse it to death for around $350
Postby bluemaumau » Tue Mar 21, 2006 11:47 pm
strx7 wrote:........4AFTE, if ya killed it you can grab another 4AFE and abuse it to death for around $350
$&#$% yea, im sure you can get them cheapa too.
:lol:
Postby touge rolla » Wed Mar 22, 2006 12:10 am
strx7 wrote: they never throw rods, they never drop their guts in a big way, they just get so bloody hot they slowly come to a halt, and not from seizing either.
dam i was hoping it would put a rod through the block, maybe i will pull the spark plugs out, place various items into the cylinders then crank it. or attack it with sledge hammer whilst running
touge rolla
Postby Dragger_Dan » Wed Mar 22, 2006 1:04 am
Play with the timing so it knocks to death.
Put oil in the fuel (won't kill it but is good fun anyway)
Put nitro fuel from a radio controlled car in it
Take off the air filter and feed in polystyrene bean bag beads
Something that requires some effort - take the sump off and loosen up one of the big ends :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
Got firearms? A round through the cam cover might have intesting results while it's sitting on rev cut.
Dragger_Dan
Postby Ae92typeX » Wed Mar 22, 2006 8:20 am
touge rolla wrote:can anyone think of any reasons (like safety) ...
touge rolla wrote: ...maybe i will ... attack it with sledge hammer whilst running
lol
Ae92typeX
Postby Pelo » Wed Mar 22, 2006 7:25 pm
Dirt from your mums garden down the oil filler :D and water
Drain oil fill it with motor up/X1R/Snake oil see what happens!
Pelo
Postby blackmk3 » Wed Mar 22, 2006 7:27 pm
we had a old mitzi mirage once....tried to kill it the bugger went for 10mins with the old brick to the floor, untill the radiator overflow blew water into the carb and stalled it, we then thaught it would be a perfect oppertunity to put about 5handfulls of dirt in the oil filler cap as with about a liter of water to wash it down.....she ran for about 2more mins before throwing a rod and kept going on 3cylinders the poor thing just wouldnt die until a awful bang when part of the rod locked up the crank at 7000rmps :D :D
ahhhh good fun
Mk3 MA70 Supra
blackmk3
Users browsing this forum: Bing [Bot] and 8 guests
