sw20 sway bar
sw20 sway bar
Postby vr4boy » Wed Mar 22, 2006 8:37 pm
i think this is what its called, attachs to the rear struts and sub-frame??? is it worth getting a thicker one made? and if so where can i get it done in auckland? prices?
1995 ae101 levin st 20v
vr4boy
Postby Ae92typeX » Wed Mar 22, 2006 8:46 pm
You can get, and it can be worth getting a thicker one...but it depends on the car and what you are wanting to achieve in the handelling dept
Ae92typeX
Postby vr4boy » Wed Mar 22, 2006 8:52 pm
what will i gain from a bigger one then?
vr4boy
Postby Ae92typeX » Wed Mar 22, 2006 9:18 pm
Theres lots to it really, heres some easy links to start with
have a read:
http://www.canadiandriver.com/articles/jk/020911.htm
http://autospeed.drive.com.au/cms/A_2359/article.html
edit: Ive never really mucked around with a sw20 setup as i have only had them on loan, never owned, so I dont want to be direct in reccomending or not, as it depends on a cars charactistics. Also, is it an early or later sw20?
Ae92typeX
Postby vr4boy » Wed Mar 22, 2006 9:26 pm
gen1 1990
vr4boy
Re: sw20 sway bar
Postby GT4 20 » Wed Mar 22, 2006 11:05 pm
vr4boy wrote:and if so where can i get it done in auckland? prices?
Snells in Penrose. I magine around the $300 mark. Had a larger front one made for my 4 recently.
However, as above, be careful as it has the potential to destroy, rather than improve the handling. Make sure your do your research before changing it.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Adamal » Wed Mar 22, 2006 11:15 pm
Go for the front before you do the rear. This is where the weight shifts to when conering, so you're more concerned about keeping that balanced than the rear.
One thing I'd recommend is a strut brace for the rear. Makes a hugely noticeable difference. Mine is a Cusco one and is fantastic.
Postby RomanV » Wed Mar 22, 2006 11:52 pm
I wouldnt reccomend beefing up the rear sway bar.
If you want better handling, I'd suggest looking at shocks/springs first, assuming that you have standard suspension.
And a rear strut brace is a good thing to have. 8)
Postby vr4boy » Thu Mar 23, 2006 8:28 pm
i already have a rear strut brace and after market suspention. was just wondering whether it would be worth it, but i think im just going to give it a miss.
vr4boy
Postby no_8wire » Thu Mar 23, 2006 10:04 pm
Always just have two standard ones mount one on top of the other...Thats what I have for my front setup as I have recently added a SW20 rear sway bar to my AW11...but having a rear sway bar thick than the front isnt a good idea leet me tell you that! haha
no_8wire
Postby pureadrenalin » Fri Mar 31, 2006 12:39 am
I just put ST sway bars in my SW20.
I would recomend researching, and knowing what it is you are trying to achieve. My car now sits very flat during cornering.
ST do recomend that you do both front and back as they are a "tuned set"
pureadrenalin
Postby vr4boy » Fri Mar 31, 2006 8:30 pm
where do you get them from? prices?
vr4boy
Postby pureadrenalin » Fri Mar 31, 2006 9:22 pm
twosrus.com
US$260 ish, but its US$240 postage 8O
pureadrenalin
Postby KinLoud » Sun Apr 02, 2006 11:16 pm
Good on you for asking first... before you spend your money.
Doing your homework before making a descision is the best thing you can do for your car.
Reducing body roll doesn't always means more cornering power. Controlling body roll - body roll can change the angle between the wheel/tyre and the road i.e. your camber angle. Most modern suspension controls this fairly well, so that some body roll doesn't change the camber much.
However if you have no body roll at all when cornering you will have lots of weight transfer which leads to less total grip! This could lead to big understeer if you go to a big front swaybar without looking at the cars handling as a whole (wheels, tyres, spring rates, swaybar rates etc.)
One of the best handling sportscars (the Lotus Elan) had no swaybars! The handling balance and grip was sorted out without needing to use swaysbars at all!
Ken
Hamilton
021 408 863
