Converting 3SGTE dizzy to multi coil direct fire ignitioin ?
Postby Mr Procrastination » Thu Mar 23, 2006 12:20 pm
Hey :)
Anyone know anything about the convertion possiblities ???
the 3sgte is going in a rwd setup in old celica and i would to remove the dizzy as it pokes right out the back of engine.
I have seen a few pis round lately of 18RGs and other old engins that apper to have had this done.
The cheaper the better, so thinking of the possablities of using standard parts of other engines.
Any help would be much appreciated.
Thanks
Oh and all so if there is a forum that this has all ready been discusted on, please feel free to direct me there. :P
Mr Procrastination
Postby suberimakuri » Thu Mar 23, 2006 1:14 pm
megasquirt ecu with edis is one option. www.megasquirt.info
suberimakuri
Postby dodgy » Thu Mar 23, 2006 1:19 pm
or look at megaJolt, its megasquirts little sister :) mmmmmm :)
http://picasso.org/mjlj/
dodgy
Postby Mr Procrastination » Thu Mar 23, 2006 2:52 pm
Umm ok sorry looks like those megaSquirt things are completle stand alone. So this would be a good time to mention i have been runing the engine on a V5 Link, so that type of unit looks like id stop using the link for ignition all together. And kind of like the ajustiblitly. So was thinking of expanding on my curent setup.
Last edited by Mr Procrastination on Fri Mar 24, 2006 3:58 am, edited 1 time in total.
Mr Procrastination
Postby Mr Procrastination » Thu Mar 23, 2006 3:02 pm
but man the megasquirt is lookin good. Maybe i should seel the link and do that. Dont suppose anyone has built one up ????
Mr Procrastination
Postby RomanV » Thu Mar 23, 2006 4:58 pm
You could pinch the coil over plug setup from an Altezza/Cadina GT/Caldina GTT, as these are already setup for a 3sg(t)e.
Although it probably wouldnt make a difference either way, I suppose.
Postby dodgy » Sun Mar 26, 2006 8:35 pm
hehehe and to combine the last 2 posts, i am running megasquirt on a 3sge with coil over plug!
dodgy
Postby RunningRich » Mon Mar 27, 2006 11:03 am
dodgy wrote:hehehe and to combine the last 2 posts, i am running megasquirt on a 3sge with coil over plug!
Out of interest, what dwell time are you running?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby dodgy » Mon Mar 27, 2006 12:17 pm
RUNING 2.3 mS AT THE MOMENT, BUT MIGHT BE A BIT TOO MUCH, FINE TUNING STILL TO COME
dodgy
Postby Mr Procrastination » Mon Mar 27, 2006 2:08 pm
Hey dodgy
What version 3sge are you running, and witch megasquirt version.
Did you keep the distributer and use the NE and G1, G2 pickups, or did you opt to remove and make just a crank angle senser.
Mr Procrastination
Postby dodgy » Mon Mar 27, 2006 6:43 pm
head is off caldina vvti beams, am running cam sensor 12-1, running verson 2.2 MSI. if you have a gen3/gen4 you have already a 32-2 tooth pickup on the cranks so can grind an extra tooth and your away!
dodgy
Postby Mr Procrastination » Mon Mar 27, 2006 7:22 pm
sounds nice. How did you find the megasquirt to build, setup and tune.
I am looking puting one on a gen2 so just has the pickups in the dizzy.
Mr Procrastination
Postby dodgy » Tue Mar 28, 2006 9:08 am
just use the dizzy wheel as a cam sensor, then you dont have to worry about the detailed wiring. unles you wanted to keep all the original wiring.. :)
dodgy
Postby RunningRich » Tue Mar 28, 2006 1:54 pm
dodgy wrote:RUNING 2.3 mS AT THE MOMENT, BUT MIGHT BE A BIT TOO MUCH, FINE TUNING STILL TO COME
I've been told 1.8ms by someone that runs a Motec, but haven't got mine set up yet. Would be interested how it goes.
Richard
RunningRich
Postby Mr Procrastination » Tue Mar 28, 2006 11:02 pm
So i take it the caldena engine was originally a coil over plug engin. Are the megasquirt ecu easy to build and set up. I a pretty able sort of a guy, usualy like to do everything myself, so thinking of giving it a good. BTW what are V5 Links werth to sell these days, basicly new :)
Mr Procrastination
Users browsing this forum: No registered users and 37 guests
