wont go into gear
wont go into gear
Postby bluemaumau » Fri Mar 24, 2006 3:24 pm
ok, im just about to go help my mate remove his gbox.
the car is a gtti (cb80) turbo charade, 3 cyc 1 litre.
last nyt he tells me he hit limiter and now the 3 banger wont go into gear,
does anybody know why this could be????
cheers in advance :D
Postby sergei » Fri Mar 24, 2006 3:36 pm
exploded clutch disc or broken shifting fork?
Postby bluemaumau » Fri Mar 24, 2006 3:53 pm
he got a brand new brass button clutch about 2 and half months ago, but its been sweet, it dosnt go into gear when still. :?
Postby RS13 » Fri Mar 24, 2006 4:13 pm
I'd say clutch. Those cars have pretty tough gearboxes. So, you put your foot on the clutch, and it doesn't go into gear? Does it do the same with the car off? If you turn the car off, make sure you're on the road with nothing in front of you, put it in first, and try and start it. If it jumps forward, I'd say clutch line or clutch plate. If it doesn't go into gear with the car off, or goes into 1st but doesn't have drive, you've broken the gearbox or shift mechanism.
RS13
Postby FrEsH » Fri Mar 24, 2006 10:00 pm
selector cables? will it go into no gears at all?
FrEsH
Postby THA SHZ » Fri Mar 24, 2006 10:04 pm
synchros possibly ? can u give a little more information ?
THA SHZ
Postby bluemaumau » Fri Mar 24, 2006 10:16 pm
no more info. it dosent matter thon the clutch is still under warrenty, and we feel its the problem :cry:
Postby Jazza » Fri Mar 24, 2006 10:20 pm
Sounds like the clutch... and why would you hit the limiter on a 1 litre 3 cyclinder? Lolz...
Jazza
Postby bluemaumau » Fri Mar 24, 2006 10:25 pm
jazza: becuz its a turbo charade... do you have any idea how insane these are? :roll:
they have steel cranks and forgies standard. ppl run 30+psi on them, my m8s only runnning 15psi cuz of boost cut, needs a aftermarket ecu, then the pounds will rise :twisted:
Postby Jazza » Fri Mar 24, 2006 10:38 pm
Ah, i dont know much about them. But i hate the look of them. Theres a green one around howick that sounds like shit... never seen another worth looking at other than that.
Jazza
Postby ollieboy » Sat Mar 25, 2006 8:39 pm
Yeah they are awesome cars man. They go real fast, also really fast into trees when your friends borrow it for the night. :evil: :( :cry:
ollieboy
Postby Loudtoy » Sat Mar 25, 2006 10:17 pm
From memory i believe there was a rather rapid one in wellington quite a few years back owned by the man with an evo which goes by the name of docile, gave quite a few people in what they thought were quick cars a fairly big fright.
Nice sleeper if you can get your hands on a good one, oh and the not being able to select anything, if you can get gears with the car off, clutch and if not he's bent something in the selection mechanisim - also some details about if it stopped being able to go into gear while he was driving it or over night
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Ae92typeX » Sun Mar 26, 2006 9:09 am
Did you get it out and find out what it was?
Could even be a collapsed release bearing
Ae92typeX
Postby bluemaumau » Sun Mar 26, 2006 12:23 pm
na its under warrenty so, hes gonna let some1 else do it. that was my felling - bearing
