So yea new springs......
Postby RickGT » Wed Mar 29, 2006 9:21 am
im after some stiffer springs for my 82 an just wondering if anyone has any info on which springs are stiffer blah blah...
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby RickGT » Wed Mar 29, 2006 11:07 pm
bump :lol:
EP91 Glanza V
RickGT
Postby RickGT » Thu Mar 30, 2006 9:17 am
so no1 noes what springs are hard and which are soft?
EP91 Glanza V
RickGT
Postby MrDori » Thu Mar 30, 2006 9:21 am
go to stocks and ask them, they may know of a stiffer replacement,
or you could get some made up, youll probly need to upgrade your dampers to altleast new ones.
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby Truenotch » Thu Mar 30, 2006 5:22 pm
Kings = too hard and crap
Jamex = softer and better
Lovells = Great springs! (can get for ae92 so should be able to for ae82)
TRD's = also great, but not sure if you can get them for ae82
I'd go for lovells personally, they will make the car handle awesome.
You should definately do shocks at the same time, get KYB's - they are good.
Howcome you wanted to know which springs are stiffer? Stiff doesn't mean it will make your car handle better.
Truenotch
Postby TruenoBZG » Thu Mar 30, 2006 5:57 pm
Ive just had JAMEX installed and the front is great - nice and stiff, but the rear is still a little 'doughy' - not as tight nor low as the front, i was told they'd settle a bit and the rear is pretty light on the AE111's
'96 Trueno BZ-G
TruenoBZG
Postby RickGT » Thu Mar 30, 2006 6:27 pm
yea i noe, already done the shocks, got b&g springs too but they arnt any better than the stock springs, only makes it lower doesnt make it more stable, shocks are monroe gt gas btw
EP91 Glanza V
RickGT
Postby RickGT » Wed Apr 12, 2006 9:31 pm
so yea revhead said i can get whiteline springs but not trd, any1 had any of these or have them? what are they like, i want something about 25-35mm drop
EP91 Glanza V
RickGT
Postby Mr Revhead » Wed Apr 12, 2006 10:32 pm
how stiff do you want?
stiff isnat alway good.. especielly on nz roads.... maybe swaybars are what you need?
Postby bluemaumau » Wed Apr 12, 2006 10:33 pm
i dont recommend jamex, id like to try TRD with my next car if i can t afford adjusties
Postby RickGT » Wed Apr 12, 2006 11:43 pm
yea i dont want like drifting stiff, but like stiffer than normal, does sway bars make it a bit stiffer,
and also replacing bushes, does it help that much?
EP91 Glanza V
RickGT
Postby escortman » Thu Apr 13, 2006 12:11 am
i had cuts, jamex lows and sabre supalows
cuts jus dodge dnt go there
jamex really nice firm but not as rock hard as kingz dropped bout 30mm+ as well still got them $150 and there urs :)
now have have the sabre supalows in to damn soft but i a cbf changing back
PM if ur interested in the jamex lows
4x4 toyota blizzard offroader
escortman
Postby RickGT » Thu Apr 13, 2006 8:52 am
just the fronts?
EP91 Glanza V
RickGT
Postby TRDWGN » Thu Apr 13, 2006 9:18 am
To get harder springs means you will need to get stiffer shocks to control them, hard spring plus standard rate shocks will just give a bouncy ride...
If it is performance you want i would approach someone like Snells springs and get them to make up so 280lb fronts and 200lb rears, however to retain any reasonable ride height they will need to be short which means shortened struts, and to control the springs you will need stiffer struts so to do the job satisfactory is going to cost $$$$
A budget approach would be to get some koni or AGX adjustable struts for the front and run a set of "insert brand here" lowered springs, the rears will suffice on std shocks and you shopuld be able to get enough damping in the front to minimise pulverising your shocks from excess travel
TRDWGN
Postby THA SHZ » Fri Apr 14, 2006 8:28 am
i have kings all round in my fxgt with koni adjustable dampner shocks at each corner , ur main problem with the softness is actually the shocks themselves , i had tryed scumroe and kyb before and it was to soft , but changed to koni and i wont go back .
if u do want the rear stiffer , then upgrade ur swaybar and u can go stiffer springs , but the only way to do it is by doing wot trdwagon said and getting custom ones made at snells , trust me i have looked at all the aftermarkets and none of them are an uprated spring 8)
hope this helps u
THA SHZ
Postby Caveman » Fri Apr 14, 2006 2:54 pm
Could you use ae92 struts plus ae82 tophats to run TRD springs? Just an idea might work :D might need to change the hubs too but ae92 have bigger brakes anyway 8)
I have whiteline springs, they are just a lowering spring set, 45mm drop. Dont know any numbers but the front is a lot harder than standard, they rear only a little harder. Handling is just meh but dont expect springs alone to improve handling much at all.
Caveman
Postby Mr Revhead » Sat Apr 15, 2006 6:54 pm
the spacing of the bolts on the strut to hub are different from ae82 to ae92
Postby TRDWGN » Sat Apr 15, 2006 9:39 pm
Mr Revhead wrote:the spacing of the bolts on the strut to hub are different from ae82 to ae92
Only on the rear, fronts are interchangable from 82 up to 111
TRDWGN
Postby RS13 » Sat Apr 15, 2006 10:43 pm
Swaybars are what you want, I've seen/driven cars whose handling was vastly improved with thicker/solid swaybars, even with factory shocks and springs. Whiteline usually want $300 - $350 with nolethane bushes, if thats' too much for you, perhaps take your factory one to an engineering workshop and see if they can make one up from thicker tube? I've heard of racecars with 2 factory ones hoseclamped together! Super rangi.. but hey, if it works..
RS13
Postby escortman » Sun Apr 16, 2006 10:52 am
yeh same here its what im going to do in the esky cut the ends of another factory swaybar and clamp together, presto double sway bar :lol:
escortman
