strut bar
strut bar
Postby bluemaumau » Fri Mar 31, 2006 12:18 am
i would like to put a strut bar on the wagon once i get the gze in. im not 100% sure but id guess a ae101 bar will fit but anyway,
these toyota bars bolt to the towers(obviously) but also bolt up to the firewall., now the wagon dosent have these holes in the firewall for this so wat can i do?
1. leave it, just bolt it to the towers
2. drill holes in firewall and bolt up.
3 another option
2- is this legit?
Postby sergei » Fri Mar 31, 2006 1:27 am
You could drill the holes and put nuts behind.
If your car is AE10X the strut brace from AE101 should fit.
Postby 20v_rollaboy » Fri Mar 31, 2006 1:28 am
Ive done it :D Drill holes and put big bolts in
20v_rollaboy
Postby barryogen » Fri Mar 31, 2006 9:15 am
isn't it illegal to modify thefirewall without a cert?
barryogen
2ZZ Guru in training
Postby sergei » Fri Mar 31, 2006 9:21 am
tell that to alarm installers, they drill holes in firewall all the time
Postby bluemaumau » Fri Mar 31, 2006 9:31 am
yea i may do it after i get a cert, cheers everyone
Postby barryogen » Fri Mar 31, 2006 10:38 am
sergei wrote:tell that to alarm installers, they drill holes in firewall all the time
I know they do it all the time(also look at speeding, jaywalking hell, lots of things), doesn't make it any less illegal.
barryogen
Postby Andy » Fri Mar 31, 2006 12:23 pm
Or if you don't want to mug around with the firewall, you could always buy an aftermarket strut brace which connects the 2 towers directly, only cost around $50 at trademe~
from Andy
Andy
Postby bluemaumau » Fri Mar 31, 2006 2:42 pm
Andy wrote:Or if you don't want to mug around with the firewall, you could always buy an aftermarket strut brace which connects the 2 towers directly, only cost around $50 at trademe~
from Andy
hmm wat brand are these?
good quality?
Postby Andy » Sat Apr 01, 2006 2:28 pm
Brand that probably no one has ever heard of. Not sure about quality as I have not bought one before, but it shouldn't be any worst than the factory brace.
from Andy
Andy
