Super Charged 3SFE Can Anyone Help
Postby XscurrenltD » Fri Mar 31, 2006 9:41 am
Hey guys has anyone super charged a 3SFE before is there a super charger that bolts on can anyone point me in some direction i have been searching google hi and low for some one who has done it??
I am stumped
XscurrenltD
Postby Silent Knight » Fri Mar 31, 2006 9:49 am
This should go to the tech section if you want help on the subject. :wink:
Silent Knight
Postby BlakJak » Sat Apr 01, 2006 9:52 pm
3SFE isn't built for performance. I somehow doubt its the best engine to choose for a 'Z' project.
And yes, post in the right forum next time eh. :)
BlakJak
Postby gordon77 » Sat Apr 01, 2006 10:33 pm
your probably best off supercharging a 3s-ge :)
What is RR?
gordon77
Postby Chickenman » Sat Apr 01, 2006 10:43 pm
I think a supercharged/turbo fe is a good Idea, better cams for low rev torque and relatively low compression.
Of course, they will explode on a regular basis but at around $300 or less for a complete replacement engine it could be a good bit of fun. Setup costs could be as little as $400 (second hand turbo and manifold, little bit of fab to get an oil drain/feed etc) and then it would be a minor issue to swap the gear over when you 'splode things.
This is assuming you can change engines/do most of the work yourself.
If not, buy a 3sgte. Turboing a 3sge is a bitch by all accounts so probably not the best suggestion either.
Baby Jesus
Chickenman
I Am The Walrus!
