1jz / 2jz waterpump q's
Postby evil_si » Fri Mar 31, 2006 10:55 pm
did either of them come with a normal waterpump, ie without the hydraulic fan drive?
evil_si
Re: 1jz / 2jz waterpump q's
Postby matt dunn » Sat Apr 01, 2006 12:04 am
evil_si wrote:did either of them come with a normal waterpump, ie without the hydraulic fan drive?
Pretty sure they did.
We modified our first 1JZ to do away with the hyd pump part,
But the 2JZ we have has just the normal looking pump.
I will be working on it tommorw at Ruapuna so will get a pic if I can.
matt
Postby Doriftering » Sat Apr 01, 2006 1:36 am
yep. my 1jz's running a normal water pump. i think the supras had normal pumps
Doriftering
Postby the fallen303 » Sat Apr 01, 2006 1:38 am
supras have the hydralic ones as well, i thought it was the soarers that came without? anyway, you can get them new from toyota for less than $100 i think. we bought two and paid stuff all for them.
true house of JZ
Stay true to the origin
the fallen303
Postby Doriftering » Sat Apr 01, 2006 1:43 am
the fallen303 wrote:supras have the hydralic ones as well, i thought it was the soarers that came without? anyway, you can get them new from toyota for less than $100 i think. we bought two and paid stuff all for them.
Yeah its one of them, the 2jz pumps bolt on the 1jz so you could do that to
Doriftering
Postby edwagon » Sat Apr 01, 2006 7:28 am
jzz30 soarers definantly have a normal pump, and the 1jz-ge ive got here out of a jzx90 chaser has a normal one as well.
The genuine pumps come with the rear housing and everything so that'd be your best best.
edwagon
Postby edwagon » Sat Apr 01, 2006 1:00 pm
Ive just checked my 2jz-ge from a jzx91 chaser and it too has a normal waterpump :D which means got a spare one here with a good waterpump, so if you get stuck give me a pm and I can probably help you out.
edwagon
Postby Silent Knight » Sat Apr 01, 2006 1:12 pm
Simon why ask when you've got my Soarer sitting right there next to you ay? :P
I've got a brand new rear housing for a 1J waterpump but the front is sitting in the Soarer at the moment if you are interested in just the rear housing for now? :lol:
Silent Knight
Postby evil_si » Sat Apr 01, 2006 2:42 pm
lol forgot about looking at yours hanre
i need the front half, preferably 2 of, 1 for a 1jz, and 1 for a 2jz. as all i want to do is get rid of the hydraulic fan,
i know i can blank it but its in the way of the second turbo.
and looks ugly as sin
evil_si
Postby strx7 » Sun Apr 02, 2006 1:09 am
there is two different bolt patterns where the pump bolts on, from memory the holes on the passengers side line up but the further to the right you go the more the holes dont line up
Postby Si » Sun Apr 02, 2006 1:48 am
less than 100 :o
for hydro ones for a jza70 ..... add another 0.......
Current: , '96 SubaruImpreza
Si
Postby BlakeNZ » Sun Apr 02, 2006 10:54 am
from my experience the JZA70 mk 3 supra has the hydro,some people swap it for the JZZ30 soarer one. Also the 2JZGTE Aristo has the hydro,swop it for the JZA80 mk4 supra one if required ,or a soarer one.
BlakeNZ
Postby KE20 » Sun Apr 02, 2006 11:49 am
when i blew my 1jzgte (from a jzx90-hydro) i tried a non hydro, and didnt fit, the patterns were different, we tried 3 different models pumps - all slightly different bolt pattern.so i got a second hand one from toyotas galore- and it started leaking after a week, so i bought the $50 washer to fix it.
but i have remove the hydro bit from it,
i dismantled pump and removed all the compnent for the hydro pump, and then reinstalled (the original pump leaked because i did not hook up hydropump,and it running dry gets hot and washer between hydro bit and water dit cracks and leaks), (2nd pump i tried hydro pumping fliud in a circle, that leaked aswell).
then i got a hacksaw and cut all that hydro crap off the pump, looks almost like a non hydro pump. havent had any proplems in over a year.
Garage Dori
KE20
Postby the fallen303 » Sun Apr 02, 2006 6:21 pm
less than 100 :o
yeah, thats the hydro one, i mean we only paid less than 100 for the non hydro one, tidyed up that area of the motor heaps and allowed us to do our intake piping how we wanted to, blakenz can vouch for that :) how ya been anyway blake? you'll have to come up again sometime and try and catch up at dads sometime. sounds like i have to thank you for some nice new toys, or 6, lol. THANKS!!
but on topic, i'll see if i can find the part number that we used for our water pumps and post it up to help people out.
true house of JZ
the fallen303
Postby Si » Sun Apr 02, 2006 6:51 pm
http://www.1jz-gte.us/documents/SubDocs ... 016-01.pdf
theres the hydro parts list/exploded view.
the hydo fan is belived to flow 5000cfm at fullspeed :D
btw there is now a EPC online for the mk2 and mk3 supras.
http://www.cygnusx1.net/supra/techtips.html
TSRM MKII Supra
TSRM MKIII Supra
EPC MKIII Supra(NATO)
EPC MKIII Supra (Non-NATO)
TEWD MKIII Supra
enjoy!
Si
