Whats the rev limiter on a AE101 4agze ?
Postby beeker » Sun Apr 02, 2006 2:55 pm
I be dammed if my google skills can find it.
exact figure please.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Bazda » Sun Apr 02, 2006 3:50 pm
7500
Postby aesc » Sun Apr 02, 2006 3:56 pm
Full redline is 7500 but I thought rev limiter was around 7800. I have accidentally revved mine past 8000 on a few occasions missing hooking 2nd gear :oops:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Rick » Sun Apr 02, 2006 4:17 pm
aesc wrote: I have accidentally revved mine past 8000 on a few occasions missing hooking 2nd gear :oops:
How did you do that??? did you remove the factory rev cut, or are you running aftermarket ecu?
Postby EVLGTZ » Sun Apr 02, 2006 4:26 pm
yeah i thought was 7800rpm as well.
Lifted mine to 8400rpm and still holding together!
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby craigt » Sun Apr 02, 2006 7:50 pm
Mine has revved past 8000 on one or two accidental occasions. Still factory ECU, dont think its been tweeked. Has a speed limiter at approx 200kph which isnt very difficult to hit at all :)
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby Bazda » Sun Apr 02, 2006 8:00 pm
my mate said his ae101 hit 8000 just reving it out through the gears i was like wtf.
cos on the dyno it cut at 7500
Postby aesc » Sun Apr 02, 2006 8:59 pm
Yeah under load id say it would cut earlier, when I revved to 8ish K it wasnt really under load
And yeah ditto to what craigt said - mines got stock ecu
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bluemaumau » Sun Apr 02, 2006 9:27 pm
is this the same for the ae92 afm? :?
Postby evil_si » Sun Apr 02, 2006 10:20 pm
im sure both my ae92 gtz and ae101 gtz would got to 7800.
the ae92 had no speed cut,
evil_si
Postby Bazda » Sun Apr 02, 2006 11:12 pm
my ae92 gtz turbo cut at 7500, hit that at least 5-10 times a day, it was impossible not to :)
Postby matt dunn » Sun Apr 02, 2006 11:42 pm
I think you will all find that at 7000 rpm onwards you will be really surprised how far out a standard or even aftermarket tacho will be,
some we've seen have been up to 600rpm out, usually on the high side.
Postby IH8TEC » Tue Apr 04, 2006 7:13 pm
yeah mine always hits at 7500-7600rpm,
evlgtz, how much boost you run it on at 8400rpm? and did you find it beneficial to raise it to that?
Postby FLAWLES » Wed Apr 05, 2006 2:29 pm
yea mine on my ae101 gtz is between 7500 and 7800
but how do you go about lifting the rev limiter? i am running a aftermarket piggy back comp?
FLAWLES
Postby mr pad » Wed Apr 05, 2006 2:50 pm
Bazda wrote:my ae92 gtz turbo cut at 7500, hit that at least 5-10 times a day, it was impossible not to :)
good man. one of my fav sounds in the world... dirty rev cut on a rb series motor = gazzim.
mr pad
