aircon
aircon
Postby bluemaumau » Mon Apr 03, 2006 11:19 pm
ok another question for the TS populace.
ive got the 4agze out now. which has aircon
the gzes going into the wagon which dosent have aircon,
i was going to remove it anyway
obviously i disconnected it from the pump when i removed the engine,
so the question is should i remove the pump, and if i do, do i need to get a custom belt made up to turn the p/s and alt (i think those are the ones on the same belt :oops: )
can t remember
ae92 gze
cheers :?
Postby Santa'sBoostinSleigh » Tue Apr 04, 2006 10:12 am
2 options:
1) remove pump and get an appropriate belt to fit (benefit - reduces a few kgs)
2) leave pump, but retain standard belt
depends how much you can be fuxed or not....
i will have to find a new belt when i take my blacktop one off
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Distrb » Tue Apr 04, 2006 11:16 am
you'll also need to find a way to tension that belt, as im pretty sure the main tensioner is useless once you remove the aircon pulley
Distrb
Regular Poster
Postby bluemaumau » Tue Apr 04, 2006 2:20 pm
hmmm, so if i leave the pump, itll still pump away wont it?
Postby MrOizo » Tue Apr 04, 2006 2:21 pm
bluemaumau wrote:hmmm, so if i leave the pump, itll still pump away wont it?
nope... it will basically be a 20kg idley :P
the aircon wont pump till it has power to engage the clutch (like the SC)
MrOizo
Toyspeed Legend
Postby 85AW20v » Tue Apr 04, 2006 3:24 pm
You should be able to adjust the belt tension with the alternator adjustment.
See ya
Simon
85 MR2 20v
85AW20v
Postby bluemaumau » Sun Dec 17, 2006 9:33 pm
bumping this up, so any one done anything else, ive stripped my engine nearly right down, barring internals, and if i can avoid putting the aircon back i will,
so...........
Postby slighty_looney » Sun Dec 17, 2006 9:50 pm
just take it out and get a belt to suit, done that on my 4age and my 3sge
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby bluemaumau » Sun Dec 17, 2006 9:51 pm
yea bro but that leaves a massive gap and little tension :wink:
Postby Adydas » Mon Dec 18, 2006 7:01 am
why not remove the pump, gut the inside so it just beacmes a free spinning wheel and put it back.
Adydas
Postby bluemaumau » Mon Dec 18, 2006 8:36 pm
good idea will look into it
Postby Alex B » Mon Dec 18, 2006 11:55 pm
It already is a free spinning wheel, why bother gutting it.
Postby Stealer Of Souls » Tue Dec 19, 2006 8:45 am
approx 8.5 kgs....
'86 AE85.5 Levin
Stealer Of Souls
Postby Alex B » Tue Dec 19, 2006 12:22 pm
Wow a whole 8kg...How much lighter is gutting it going to make it??
Postby samlloyd » Tue Dec 19, 2006 5:28 pm
8kg?
samlloyd
Postby bluemaumau » Tue Dec 19, 2006 5:32 pm
whether its 8 kg or not its un needed in a already packed engine bay
