starter motor *URGENT*
Postby bluemaumau » Wed Apr 12, 2006 6:17 pm
hey everyone
my 4agze afm has a starter motor problem,
i would like to begin putting the gze into the rolla this weekend so i want to do this whilst the engines out,
whats my best bet?
1. replce with new item
2. replace with used item
- will the starter motor from any other 4age or model fit?
3. recondition old item?
any help is appreciated,
anyone on TS who does reconditioning? its off the motor btw
Postby Ae92typeX » Wed Apr 12, 2006 7:51 pm
whats the problem with it?
most common thing on starters is simply the brushes being worn and in need of replacement (easy as job). sometimes solenoids stick, but the can be cleaned up or replaced. Only other thing Ive had with a few toyota starters is the bush on the gear end wearing...again, easy enough to repair/replace.
I'd do that if it was mine, but then again, if $$ is no issue...
Ae92typeX
Postby CAMB01 » Wed Apr 12, 2006 11:13 pm
If you are using a GZE gearbox you have to use the GZE starter motor.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Wed Apr 12, 2006 11:29 pm
CAMB01 wrote:If you are using a GZE gearbox you have to use the GZE starter motor.
im using a e52, thanks for that :D
so anybody got one that works?
or can rebuild?
Postby matt dunn » Wed Apr 12, 2006 11:34 pm
Ae92typeX wrote:whats the problem with it?
most common thing on starters is simply the brishes being worn and in need of replacement. sometimes solenoids stick, but the can be cleaned up or replaced. Only other thing Ive had with a few toyota starters is the bush on the gear end wearing...again, easy enough to repair/replace.
I'd do that, but then again, if $$ is no issue...
Correct but not with the GZE as they are gear reduction.
Only the earlier type do that.
The common gear reduction ones,
1 in 50 will have worn brushes,
about 1 in 40 will have faulty solenoid windings,
the dont have bushes' at all, fully bearing'd.
99% have worn contacts in the solenoid which can be replaced easy as without having to replace the whole solenoid.
Also they suffer a lot from voltage drop to the starter operating sw.
We do those type's at work every day.
Matt
Postby bluemaumau » Thu Apr 13, 2006 12:20 am
so are you saying its a sort of easy repair job? :D
Matt
Postby matt dunn » Thu Apr 13, 2006 12:37 am
bluemaumau wrote:so are you saying its a sort of easy repair job? :D
Yeah, if you've done as many as I have they are.
If you want to send it down I can do it at a not too bad price.
PM me if your keen.
matt
