Fiat starter motor compatibility?
Postby ollieboy » Thu Apr 13, 2006 12:14 am
I realise this is not toyota related but I have this Uno sitting round home that has been sitting there since Christmas, the only thing wrong with it is its an Uno, sorry I mean the only thing wrong with it is its starter motor is gone. I have a few starter motors lying round and was wondering would one of these work. No idea what type they are just wondering if any starter motor works on any engine.
ollieboy
Postby Ae92typeX » Thu Apr 13, 2006 12:25 am
All depends on the mounts and pinion teeth. starters are not universal, some may work, others may not. is it gone as in not there, or just broken?
Ae92typeX
Postby ollieboy » Thu Apr 13, 2006 12:29 am
Its not there.
I might just connect a couple up see if they work but the engines covered in oil and its a messy job, oh well.
ollieboy
Postby Ae92typeX » Thu Apr 13, 2006 10:16 am
I'd be careful when doing so, as you could damage the ring gear on the flywheel. if possible, open the solenoid by hand and turn the starter by hand to see if it meshes. thats not really as easy to do as say, since you cant see if it is meshing....but yeah, just be aware of possible damage that can be caused.
Ae92typeX
Postby sergei » Thu Apr 13, 2006 12:04 pm
You could try going to pickapart and try one off LADA...
Postby CaM » Thu Apr 13, 2006 12:56 pm
plenty of rustry unos about. justr get on from a wreckers
CaM
