torque settings for cv nut (ae92)
Postby deaf_rattle » Thu Apr 20, 2006 11:02 pm
will be removing my cv joint tomorrow. does anyone know what torque the large nut needs to be torqued up to?
the one you see when the centre cap is removed from the wheel
Postby Lloyd » Thu Apr 20, 2006 11:20 pm
Tight as f*ck. Just use a 1/2inch rattle gun if you have one, or a big bar. And put a little oil/grease on either side of the washer or on the surface of the nut if there is no washer, seen a few examples of noise from hubs and things which tunred out to be CV nuts not quite tight enough because of this
Postby IH8TEC » Thu Apr 20, 2006 11:20 pm
wrist :lol:
Postby Caveman » Thu Apr 20, 2006 11:46 pm
What he said
Stand on a bar with a big arse socket
Caveman
Postby edwagon » Fri Apr 21, 2006 12:03 am
as tight as you can get, then a bit more. get someone to stand on brakes while you jump on the bar you-re using to tighten it. If you can get a torque setting, great, but its likely to require this method anyway!
edwagon
Postby 85AW20v » Fri Apr 21, 2006 12:11 am
And after a few hundred km's, check them again as they may move and setlle into place a bit more. Has happened on the race car more than once.
See ya
Simon
85 MR2 20v
85AW20v
Postby bluemaumau » Fri Apr 21, 2006 12:37 am
:P :lol:
but seriously does anyone know were to get a socket long enough to actually grip this nut?
as mine dont reach it because of the overhang from the shaft! :evil:
Postby Grrrrrrr! » Fri Apr 21, 2006 12:47 am
i use a 3/4" drive powerbar (about 1.5 mtrs long...) socket is just deep enough to do the job properly. and nice long powerbar for good leverage
Grrrrrrr!
Postby Lloyd » Fri Apr 21, 2006 8:26 am
Most places should be able to sell you something to suit. Deep 30 or 32mm impact socket. Some of them even say "Axle Nut" on the socket :P
Postby Ae92typeX » Fri Apr 21, 2006 9:08 am
Grrrrrrr! wrote:i use a 3/4" drive powerbar (about 1.5 mtrs long...) socket is just deep enough to do the job properly. and nice long powerbar for good leverage
Yeah, I use a 1" set. But really, there is a correct torque setting as its more than possible (i.e. very easy) to over tigthen them. My Aw11 manual has the setting for it...but I cant see it offhand. its not near the amount I could put on with my 1" sockets.
Simon85MR220v wrote:And after a few hundred km's, check them again as they may move and setlle into place a bit more. Has happened on the race car more than once.
I'd agree with this also, seen it to be the case several times, especially if a press is not used to fit bearing.
Ae92typeX
Postby sergei » Fri Apr 21, 2006 9:23 am
the normal "torque" is 130-160Nm (from memory), and no rattle gun is not strong enough
Postby deaf_rattle » Fri Apr 21, 2006 10:25 am
sweet thanks guys.
i heard the use of a rattle gun is not good, because the vibration may cause a cv joint to crap out?
Postby Bazda » Fri Apr 21, 2006 10:33 am
sergei wrote:the normal "torque" is 130-160Nm (from memory), and no rattle gun is not strong enough
we use rattle gun everyday at the workshop. Im pretty sure its strong enough, on low setting it torques nuts up to 95ft pounds
Postby pc » Fri Apr 21, 2006 2:14 pm
my ae82 manual says around 130-140 foot pounds. tight as %$#@ for big strong person may be 250 foot pounds, so use a torque wrench.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ATAl » Sat Apr 22, 2006 11:22 am
I did this the other day and the torque setting is ~140lbft.
The nut is 30mm, you should be able to use a normal 30mm socket to get the nut off and on again unless the car is a supercharged model, on them the bit which the nut screws onto is longer and you'll need to use a deep socket.
ATAl
