will be removing my cv joint tomorrow. does anyone know what torque the large nut needs to be torqued up to?
the one you see when the centre cap is removed from the wheel
1998 wrote:What he said
Stand on a bar with a big arse socket
Grrrrrrr! wrote:i use a 3/4" drive powerbar (about 1.5 mtrs long...) socket is just deep enough to do the job properly. and nice long powerbar for good leverage
Simon85MR220v wrote:And after a few hundred km's, check them again as they may move and setlle into place a bit more. Has happened on the race car more than once.
sergei wrote:the normal "torque" is 130-160Nm (from memory), and no rattle gun is not strong enough
