Torque settings for exhaust manifold stud into block [3SGTE]
Postby Wildcard » Fri Apr 21, 2006 10:54 pm
When I took my turbo off to fix the warped manifold I had 3 studs wind out of the block at the same time, so I'm going to replace these. About to put new studs in, so what torque figures should I use?
Wildcard
Toyspeed Founder
Postby Mr Revhead » Fri Apr 21, 2006 11:33 pm
FT!
:P
if no helpful answer by monday email me and ill read a book at work
Postby sergei » Fri Apr 21, 2006 11:54 pm
finger tight, locktite optional (makes pain in the butt if you break the stud)...
Postby Wildcard » Sat Apr 22, 2006 12:01 am
Uh, so if FT, what stops the stud winding out?
Wildcard
Toyspeed Founder
Postby Mr Revhead » Sat Apr 22, 2006 12:04 am
dont listen to me.....
well, not the first half anyway
Postby sergei » Sat Apr 22, 2006 12:23 am
well, by tightning the nut on the stud you will tighten the stud as well. If you try to tighten the stud, there is a risk of stripping/damaging the thread, as either stud will press against the end of the thread in the head or end of the thread in the stud. In this case the force will not be distributed across whole length of the thread, but only on first couple of turns (or last if it is stopped by end of the thread on the stud).
Postby Wildcard » Sat Apr 22, 2006 12:37 am
After further reading and thought, you are right, thanks for the feedback
Wildcard
Toyspeed Founder
Postby Akane » Sat Apr 22, 2006 2:56 am
and btw, locktite on exhaust parts is almost as good as a wet matchstick imo.
Postby Dell'Orto » Sat Apr 22, 2006 12:55 pm
yeah pretty much, most Loctite products are only good to ~300c....turbo manifolds seem to get a touch hotter than that ;)
Postby sergei » Sat Apr 22, 2006 6:06 pm
but the stud does not heat that much, it is in the head any way, if say alloy was heated to 300'C, it would become soft and stud would literaly be pulled out..
