detomaso help
detomaso help
Postby shaggz » Sat Apr 22, 2006 11:04 am
hi all, in know its not a toyota, but does anyone know where the factory oil pressure sensor and the factory water temp sensor are on a detomaso,engine code is hd-eg, i have tried pretty much all the sensors i can find and havent found them, i am putting in after market guages hense my problem any help would be awesome,
p.s all might not be lost it may get a re power with a 4agze, or maybe a blacktop it is going to get turned into a circuit car eventually
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Re: detomaso help
Postby Ae92typeX » Sat Apr 22, 2006 6:24 pm
stephen bedford wrote:...p.s all might not be lost it may get a re power with a 4agze, or maybe a blacktop it is going to get turned into a circuit car eventually
dont do that, there a gem of an engine...if anything turbo the existing one.
As for the sensors, if you are still stuck late next week I will look at my mates. I remember mucking round with them when I last serviced her car, but that was a good few months ago now. theres several people on here with detoms though, so someone should be able to help.
Ae92typeX
Postby Mr Revhead » Sat Apr 22, 2006 6:27 pm
throw it away and put in the 3cyl turbo engine!!!!
:twisted:
Postby ollieboy » Sat Apr 22, 2006 9:14 pm
excuse my ignorance but whats a detomaso? I searched google but got nothing.
ollieboy
Postby Mr.Phreak » Sat Apr 22, 2006 9:24 pm
try searching for De Tomaso....and I'm guessing he's talking about the Charade
Mr.Phreak
Postby Leon » Sat Apr 22, 2006 9:27 pm
Daihatsu Charade Detomaso
http://www.mrtrally.com.au/performance/maga.htm
my daily driver too.
Postby ollieboy » Sat Apr 22, 2006 9:32 pm
Oh I see now. Cool cars!
ollieboy
Postby Hachiroku » Sun Apr 23, 2006 2:29 am
The De Tomaso Pantera is the real deal.
Hachiroku
Postby snwtoy » Sun Apr 23, 2006 10:57 am
Hachiroku wrote:The De Tomaso Pantera is the real deal.
They're both worked on by the same fella.
stephen bedford: Try bbs.daihard.org - they're a harsh lot if you ask stupid questions, but if you're sensible and don't use txt talk you will get a good answer.
snwtoy
Postby Leon » Sun Apr 23, 2006 4:54 pm
Indeed.
However, not readily available for under $4000.
Postby Boosted_162 » Sun Apr 23, 2006 5:18 pm
I just had a quick look on mine, and i couldnt see them :?. If your stuck still soon i can go have a good look, but i have back problems at the mo :(
cheers all
Postby shaggz » Mon Apr 24, 2006 1:32 pm
i have just joined up with daihard.org, so will soon ask them
yip im still stuck at mo, but ill wait for there reply, and to ae92typex and at this stage i am about to purchase a td04 4 a very good price so i will forceify the standard motor for now then maybe something a bit stronger if it goes pop, but from what ive been able to find 10psi is a safe number of puff to run,
cheers if anyone does find the sensors please post
shaggz
