Whats the impedence of gze+bluetop injectors?
Postby crnkin » Mon Apr 24, 2006 4:33 pm
I did a search, but seems to just stall for 5 mins then loose the connection
I cant remember, so please help!
Looking to experiment with 4agte setup
cheers!
deaf_homo "currrently yes"
crnkin
Postby Lloyd » Mon Apr 24, 2006 4:48 pm
GZE are low impedance. Around the 2 ohm mark from memory
EDIT - Seems all 4AGE injectors are low impedance?
http://my.tele2.ee/levintrueno/engine/engine.htm
Postby crnkin » Mon Apr 24, 2006 7:49 pm
hmmm, according to that list your right, i was sure there was a high impedance injector that i was to avoid, can anyone shed light on the subject?
crnkin
Postby Donor » Mon Apr 24, 2006 7:54 pm
So what impedance injectors would you run with a link? is the impedance the resistance between the inj terminals?
Donor
Postby crnkin » Mon Apr 24, 2006 7:56 pm
yes its the total individual resistance of the injector solenoid. Link can use anything as far as im aware
crnkin
Postby Lloyd » Mon Apr 24, 2006 8:05 pm
Older Links were supposed to be high resistance, not sure on the new ones. Hence the need for resistor packs for the injectors.
And yes it is resistance between the terminals. Low impedance are usually around the 2-3 ohm mark and high impedance up around the 12-14 ohm.
Postby Caveman » Mon Apr 24, 2006 11:59 pm
Small port injectors are 13.7 ohm. High impedence
Big port are low impedence
Supercharger are low impedence. Around 3 ohm IIRC
Caveman
Postby crnkin » Tue Apr 25, 2006 9:20 pm
thanks 1998! im gonna buy a few different types and see what the highest cc'd injectors i can run for good drivability but good boost.
cher
crnkin
