Air Intake Sensor Mod
Postby bubz » Tue Apr 25, 2006 1:50 am
Hi,what is this intake sensor mod all about.This so called racing chips being sold on e-bay and on trademe now.Wot are the pros and cons of it?Does it really work?Just being curious about it.
bubz
Postby Akane » Tue Apr 25, 2006 3:16 am
It's an extreme mod where you put a resistor on the air intake temp sensor, tricking it to think the air is cold, so more fuel and more timing.
It's extremeeeeee!
Postby TrouserFxGt » Tue Apr 25, 2006 10:22 am
Akane wrote:It's an extreme mod where you put a resistor on the air intake temp sensor, tricking it to think the air is cold, so more fuel and more timing.
It's extremeeeeeeme!
Very Xtreme
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby bubz » Tue Apr 25, 2006 12:33 pm
Thanx,but does that help you go fast?Wot disadvantages will this have on the car.The actual air will still be of different temp. so how will more fuel help?
1997 Gtt Caldina Tiptronic
bubz
Postby Bling » Tue Apr 25, 2006 1:20 pm
i'll be nice and say its bollocks.... useless.... and utter crap..... do a search for mods that gain REAL power on these forums :)
Postby MrOizo » Tue Apr 25, 2006 1:39 pm
if you have a hori turbo setup... ie can afford turbo but nothing else, then this will help.
more air needs more fuel. NA ecu only knows up to atmosphere pressure.
this isnt ideal as fuel delivery is not proportional to air volume/density.
other than just being X-stream in theory - it also makes it sound mean by running like shit when you get too much / too little fuel. like a rotor... bop bop bop... bang!
MrOizo
Toyspeed Legend
Postby Adamal » Tue Apr 25, 2006 3:04 pm
Toyota put air temp sensors in for a reason, because different air temperatures have different densities. This, along with the pressure sensed from the MAP sensor will let your ECU calculate that nominal air to fuel ratio and stop your engine from overfueling or leaning out.
It won't help you go fast, but it will help you go slow :)
Postby Caveman » Tue Apr 25, 2006 3:32 pm
You will run rich and cause more problems that gains.
You will use more fuel with no increase in power :?
Caveman
Postby slighty_looney » Tue Apr 25, 2006 6:07 pm
yep then if u run rich for 2 long, gud by bottum end, as my mate jst found out with his blacktop
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby bubz » Wed Apr 26, 2006 12:17 am
Thanx guys.I thought so it was crap :x
bubz
