bleeding systems and fluids
Postby bluemaumau » Tue Apr 25, 2006 9:31 pm
ok i am nearly at the stage were everything needs to be put back together,
ae92 4agze afm :D
everything has been drained( engine and gbox oil, p/s, brake, clutch, radiator)
QUESTION 1 which of these systems will need to be bleeded?
i know brakes but the clutch is hydraulic so this too? anything else? p/s?
QUESTION 2 does the water/ radiater /coolant system need any special additives?
antifreeze etc? anything else.
can anybody recommend a good
* oil
* gearbox oil
* p/s fluid
* brake fluid
* clutch fluid
* coolant additive
cheers for the help
will :D [/b]
Postby bluemaumau » Tue Apr 25, 2006 10:01 pm
bump 8)
Postby Silent Knight » Tue Apr 25, 2006 10:14 pm
I'd say do your clutch/brakes and power steering. While your doing it all it's better to do the whole lot so you know it's done.
Give the radiator/engine/coolant system all a good flush just with water running through it with a hoze whilest the car is running then fill it with antifreeze and water. You'll have to look on the antifreeze bottel what sorta ratio you have to fill it with the water with.
Clutch and break fluid is the same. Use DOT 5.1
Gearbox oil, just check what Toyota recommends for your engine and use that.
Silent Knight
Postby bluemaumau » Tue Apr 25, 2006 10:16 pm
Silent Knight wrote:I'd say do your clutch/brakes and power steering. While your doing it all it's better to do the whole lot so you know it's done.
cheers very helpful
Postby bluemaumau » Tue Apr 25, 2006 10:19 pm
[quote="Silent Knight"].Give the radiator/engine/coolant system all a good flush just with water running through it with a hoze whilest the car is running then fill it with antifreeze and water.quote]
is that sweet while its running?
so what i connect everything up, then pull off a radiator hose and put a garden hose into it, then let the pump take care of the rest???
will :D
Postby Silent Knight » Tue Apr 25, 2006 10:35 pm
I have to try and remember which way around this goes now... :P
I think from memory how we normally do it is remove the the coolant pipe at the back of the motor just in front of the firewall and then I think it was the top radiator hose or maybe just the radiator cap.
Then just put the water hoze in to the rear hoze and make sure it's not pissing water out the sides so hold it tight while the motor is running and water will just come out the other side.
This way all the crap runs out with the water that's running out. Once the water runs out nice and clean drain everything and fill with the anti freeze.
Silent Knight
Postby bluemaumau » Tue Apr 25, 2006 10:39 pm
is it possible to do this whilst the engines off?
whilst its on the barn floor :lol: :P :oops:
Postby Silent Knight » Tue Apr 25, 2006 10:52 pm
Why yes, yes it is.
Silent Knight
Postby dazzag » Tue Apr 25, 2006 10:55 pm
the best way to flush the cooling system is with the engine off .first take the thermostat out, then take off the top radiator hose and reverse flush it by putting the hose in facing the engine. turn on the hose and flush untill water runs clear out of the top of the radiator hose. put the radiator hose back on then the thermostat back in and fill the system with coolant. start the car, warm up the engine and bleed the air.........
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby bluemaumau » Tue Apr 25, 2006 10:58 pm
dazzag wrote:the best way to flush the cooling system is with the engine off .first take the thermostat out, then take off the top radiator hose and reverse flush it by putting the hose in facing the engine. turn on the hose and flush untill water runs clear out of the top of the radiator hose. put the radiator hose back on then the thermostat back in and fill the system with coolant. start the car, warm up the engine and bleed the air.........
huh, how do you do that?
Postby beeker » Wed Apr 26, 2006 7:42 am
Go and get a service manual for your car. It'll teach you the basics on how to do this stuff, and help ensure you dont do anything silly and provide you with more confiidence.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Silent Knight » Wed Apr 26, 2006 9:22 am
Yes, I'd have to agree to what dazzag has said. When you've finished flushing and refilling the coolant system start your car with the radiator cap removed.
This will give you the chance to keep filling it untill there's enough fluid in there and you can also bleed the system of all the little air pockets that might be sitting around. You'll see the coolant bubble as the car is running and after a while it should stop and you'll only see a line of coolant run. Once you see that you can be save with the knowledge that there is no more silly little air pockets. :D
A manual would be a good start if you are not overly confident with doing work yourself. Things like flushing systems etc are really easy though. Not much you can really screw up or break whilst doing it...
Silent Knight
Postby bluemaumau » Wed Apr 26, 2006 10:04 am
Silent Knight wrote:Yes, I'd have to agree to what dazzag has said. When you've finished flushing and refilling the coolant system start your car with the radiator cap removed.
yea sweet i just didnt know how to bleed it of air bubbles,
OK so what about p/s any need to bleed that?
Postby Grrrrrrr! » Wed Apr 26, 2006 8:08 pm
My guess on how to do power steering..
Fill the top tank to almost fill while the engine is running, crank the steering from full lock one way to full lock the other way a couple of times, check and top up the fluid level and repeat again..
keep doing it till there is no drop in fluid level and you should be sweet.
oh yeah, dont forget the fluid resv. has hot and cold levels marked.
Grrrrrrr!
Postby dazzag » Wed Apr 26, 2006 8:45 pm
Grrrrrrr! wrote:My guess on how to do power steering..
you guessed correct
dazzag
Postby flat_0ut » Sat Apr 29, 2006 11:37 am
how do you take the thermostat off? easy job on an ae92 (4age)?
flat_0ut
Postby Ae92typeX » Sat Apr 29, 2006 11:56 am
flat_0ut wrote:how do you take the thermostat off? easy job on an ae92 (4age)?
easy as. afew bolts on the housing and its off.
Ae92typeX
Postby Crucible » Sat Apr 29, 2006 8:36 pm
dazzag wrote: turn on the hose and flush untill water runs clear out of the top of the radiator hose
Just a sidenote.....Giving blasts of compressed air while the water is flushing helps cavitate and pick up loose scale so you get a better flush but yeah dazzag is on the money :lol:
Crucible
Real Life Mechanic
Postby bluemaumau » Sat Apr 29, 2006 8:40 pm
also is there anything special you need to do when replacing the thermo, something about as jiggle pin???
Postby Crucible » Sat Apr 29, 2006 10:42 pm
bluemaumau wrote:also is there anything special you need to do when replacing the thermo, something about as jiggle pin???
Mount it with the hole up top so it can bleed air.
Crucible
Real Life Mechanic
